01-09-2013 05:08 AM - edited 03-16-2019 03:04 PM
Hi There,
I have a Unity connection 8.0 (2). From few days users are reporting that the mails are delayed. The voice mail left at 8 AM reached user Mailbox at around 5 PM... Any idea what is causing the delay.. ?? Please help me..
01-09-2013 05:46 AM
Did you resync all mwi on the server? Do you have dedicated ports for MWI on the Unity server? Also do you have another Unity server still active on your network?
Yosh
01-09-2013 05:56 AM
Hi Yosh,
Thanks for the reply. Ya.. I do have dedicated ports for WMI, and I do have a subscriber for Unity Connection which is still active. Do mention here, now the Subscriber is acting as primary since there is an issue running with the primary. Can you please tell me how do i resync the wmi on server. ??
01-09-2013 06:13 AM
First thing first if you could you should have dedicated ports for MWI for each server. Verify that the Subscriber does have the Primary status and that it has voice ports for MWI.
To resync all MWI go to Cisco Unity Connection Administratoon page and under Telephony Integrations>Phone System select your phone system and click the "Run" button to "Synchronize All MWIs on This Phone System"
Yosh
01-09-2013 06:17 AM
Some more info on voice ports best practices.
Each Cisco Unity Connection server in a Connection cluster must have voice messaging ports designated for the following dial-out functions in case either server has an outage:
•Sending message waiting indicators (MWIs).
•Performing message notifications.
•Allowing telephone record and playback (TRAP) connections.
As a best practice, we recommend that you dedicate an adequate number of voice messaging ports for these dial-out functions. These dedicated dial-out ports should not receive incoming calls and should not be enabled for answering calls.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/design/guide/8xcucdg060.html
Yosh
01-17-2013 06:00 AM
Hi Yosh,
Issue is resolved now... There was an issue with the subscriber (Connection), so our team had changed the Pub as primary. After reverting the changes it is working fine.. Don't know what exactly was causing the issue.
