05-31-2011 01:02 PM - edited 03-16-2019 05:13 AM
Hey all,
I'm getting a problem with a CUE here: It's a 2821 router ( c2800nm-adventerprisek9-mz.124-25a.bin) and config for the NM-CUE module is the following:
interface Service-Engine1/0
ip address 192.168.254.1 255.255.255.252
service-module ip address 192.168.254.2 255.255.255.252
service-module ip default-gateway 192.168.254.1
ip forward-protocol nd
ip route 192.168.254.2 255.255.255.255 Service-Engine1/0
05-31-2011 01:57 PM
Hello Karl,
I never configured the Service Engine interface with "ip address" command as you did. I always bind it with the Loopback interface.
Can you try the follwing:
Interface loopback 0
ip unnumberd loopback 0
no shut
Let me know what happends.
Best regards,
Nizar
05-31-2011 02:04 PM
Hey Nizar,
Thanks for replying.
I did it already. As far as I know, both ways are allowed - with IP direct at the Service-Engine interface or using the IP unnumbered from a loopback.
I have just did it, anyway:
ip unnumbered Loopback0
service-module ip address 192.168.254.2 255.255.255.0
ip route 0.0.0.0 0.0.0.0 189.125.7.13
Router#ping 192.168.254.1
Sending 5, 100-byte ICMP Echos to 192.168.254.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router#ping 192.168.254.2
Sending 5, 100-byte ICMP Echos to 192.168.254.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
So, the problem is still the same, no matter the config I do...
thx,
Karl
05-31-2011 03:25 PM
I was looking for the same issue and found one topic which has same issue like yours. they replaced the CUE.
please take a look:
http://www.dslreports.com/forum/r24735852-HW-AIMCUE-card-issues-on-cisco2821
Hope this helps.
Best regards,
Nizar
06-01-2011 04:54 AM
Hi Nizar,
It seems that I have a faulty module. According to the link you posted, I think I'll have to find a way of replacing it =(
Anyway, thanks for replying!
Karl
05-31-2011 03:48 PM
Hi Karl,
What is the output of 'service module service-engine 1/0 status'. Are you able to session to the CUE module?
Chris
06-01-2011 04:47 AM
Hello Chris,
The output is the following:
Router#
06-01-2011 05:13 AM
Hi Karl,
It looks like a defective module:
06-01-2011 05:16 AM
Chris,
This is not a production module. I'm doing some lab with it before putting it on production.
What exactly did you do? Only a reset via CLI? Could you explain me the steps?
Karl
06-01-2011 05:29 AM
Hi Karl,
It was a combination of re-seating the module and running the CLI command I mentioned. I was still able to session into my CUE module (service module service-engine 1/0 session) and was able to reload the OS via. the *** method when the module first booted up. My issue was that the modules OS was corrupted and had to be reloaded.
HTH,
Chris
Please rate helpful posts
