Cisco Unity Server 8.0 to Latest available Cisco Unity Connection 8.5 or 8.6
yogesh rajguru
We wanted to upgrade existing Cisco Unity Server 8.0 to Latest available Cisco Unity Connection 8.5 or 8.6.
The details about the existing Setup is:
Hardware part no                                   MCS-7835-I3
Windows OS                                         Windows Server 2003
Unity exact version                                Cisco Unity 8.0 Build 8.0(3.1)
Cisco Unified Call Manager - System version: 8.5.1.12025-1 (Praposed)
Cisco Unified Presence Server - System Version: 8.5.2.10000-49
Cisco Unified Persona Communicator  - Version 8.5.1.17660
Cisco Unified Mobility Advantage Server - Version
Cisco Unified Mobility User Portal - Version
Dial Via Office - Cisco Mobile version 7.1.029
Click to Call – inbuilt in CUPc
Cisco Jabbar for Android-
Below details are the details which we are looking:
1) Compatibility Cisco Unity Connection 8.5 or 8.6 with existing devices both Hardware & Software wise.
2) Backup & Restore will work from Existing to latest Cisco Unity Connection 8.5 or 8.6
3) Additional Licensing required for Cisco Unity Connection 8.5 or 8.6.
Yogesh.
Recovery disk is not for new installs, it's right telling you there's no image in there, as you don't have it installed.
Make sure the other image MD5 is correct and there was no error burning the image to physical media.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
9 Replies 9
ronpatel
Level 8
Level 8
COBRAS is to be used for Unity to Unity connection migration.
Below are two supported procedeure.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug022.html
or
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/upgrade/guide/8xcucrug024.html
Ronak patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
anchoudh
Level 9
Level 9
Hi Yogesh,
1. For hardware compatiability please check the below link,
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html#wp776999
2. Backup and Restore works only on the same version, i.e Restoring the backup of 8.0 on 8.5\8.6 will fail.
3. Please take a look at the following link:
System Requirements for Cisco Unity Connection Release 8.x, Licensing Requirements
http://tools.cisco.com/squish/3D3ff
For Downloading the software,
http://www.cisco.com/cisco/software/release.html?mdfid=283819608&flowid=26424&softwareid=282074295&release=8.6%282a%29&relind=AVAILABLE&rellifecycle=&reltype=latest
Hope it helps,
Anand
Hi Anand,
I realize that this is an old post and the link you posted is no longer available.
If i'm not mistaking, this is the software that needs to be dowloaded:
UCSInstall_UCOS_8.6.2.20000-2.sgn.iso according to some documents i've consulted. But this image is non-bootable.
Is there an additional software needed to upgrade from Unity 7 (running on windows 2003) to Unity Connection 8.6 (running on Linux)?
There are no bootable images available to download on CCO, you need to order the install media via PUT.
Rest of the process is the same as previously mentioned, you use COBRAS for the data migration between Unity and CUC.
java
java
I downloaded 2 iso images from PUT and the following license:
UNCN8-UTYMG-K9=
I burned the two images below:
8.6.2.20000-2-recovery
UCSInstall_UCOS_8.6.2.20000_2
The recovery DVD gives you the option to wipe the server clean.
The UCSInstall dvd cannot be read by the server.
I cannot boot from it either.
To be more precise, when i boot from the recovery disk, i get the following menu:
Welcome to Cisco Unified Communications Recovery Disk
Version 8.6.2.20000-2
No Valid image found on the hard drive
Please enter one of hte following options:
[f] Check and correct disk file system
[v] Verify the disk partitioning layout
[c] Cleans the system to bare metal state
[q] Quit this recovery disk program
java
java
Hi Pascal,
I'll just add one note to the great info from Java. The only CUC "build"
.iso available for download is this one;
Cisco Unity Connection DVD Is Not Required for Installing a New 8.0(3) Server
Revised August 18, 2010
The version 8.0(3) software application posted on the Cisco Unity  Connection download site on Cisco.com can be used to install a new  Connection 8.0(3) server.
In earlier versions, a Cisco Unity Connection DVD shipped from Cisco was  required to install a new server, and the application posted on  Cisco.com could be used only to upgrade an existing Connection server.
This change is applicable only to the 8.0(3) release.
It does not apply to 8.0(3a) and later, for which a Cisco Unity  Connection DVD shipped from Cisco is still required to install a new  server.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/803cucrn.html#wp716806
Cheers!
Rob
"Always movin' ahead and never lookin' back" - Springsteen
Hi Java,
You hit the bullseye with that MD5 verification.
I downloaded one more time and made sure the MD5 was verified.
Booted my server with the DVD and now i'm going thru media verification check.
Can't thank you enough.
Will let you know if i face any other issues.
@Rob: Thanks for the tip
Cheers
