Cisco Unity Version 8.6 Cluster Connection Issue
mprather89
We are running a cluster with 2 CUC server with version 8.6 on them, after a recent reboot of both server we were having replication issues and I was able to solve the problem following some steps from a different forum post about dbreplication resets.
we are currently still experience an issue when logging into the CUC publisher via the web interface we get the following error message "Communication is not functioning correctly between the servers in the Cisco Unity Connection cluster." and when logging into the subscriber we receive the same message along with "The Cisco Unity Connection cluster subscriber server has changed to Primary status(failover has occurred)."
Both the Publisher and Subscriber are currently running in a Primary state and when I got to use the Cluster management tool all the buttons are greyed out so I cannot change anything.
here is an out put from the Publisher:
admin:show cuc cluster status
Server Name   Member ID  Server State  Internal State           Reason
001  0          Primary       Pri Active Disconnected  Normal
002  1          Disconnected  Unknown                  Unknown
Database replication is not active
Output from the Subcriber:
ACE_File_Lock::ACE_File_Lock: Permission denied /dev/shm/CCM_GENstatusLock_0
001  0          Disconnected  Unknown                       Unknown
002  1          Primary       Sec Act Primary Disconnected  Normal
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_ciscounity_pub      100 Active   Dropped    3913882 Sep 28 16:09:11
g_ciscounity_sub1     101 Active   Local           0
SERVERS
Server            Peer              ID   State    Status     Queue  Connection Changed
g_ciscounity_sub1 g_ciscounity_pub  100  Active   Dropped    3913882 Sep 28 16:09:11
STATE
Source            ER               Capture          Network          Apply
                  State            State            State            State
g_ciscounity_pub  Shut Down        Uninitialized    Down             Uninitialized
g_ciscounity_sub1 Active           Running          Running          Uninitialized
Runtimestate looks good to me:
DB and Replication Services: ALL RUNNING
Cluster Replication State: Replication status command started at: 2015-09-28-07-06
     Replication status command COMPLETED 541 tables checked out of 541
     No Errors or Mismatches found.
     Use 'file view activelog cm/trace/dbl/sdi/ReplicationStatus.2015_09_28_07_06_55.out' to see the details
DB Version: ccm8_6_1_20007_2
Number of replicated tables: 541
Cluster Detailed View from PUB (2 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
001    xxx.xxx.xxx.22   0.043   Yes     Connected       0       match   Yes     (2) PUB Setup Completed
002    xxx.xxx.xxx.50   0.293   Yes     Connected       140     match   Yes     (2) Setup Completed
so from what I can see replication is working and the devices appear to be talking to each other so why am I receiving these error messages and how can I fix this issue?
6 Replies 6
Wilson Samuel
Level 7
Level 7
In my experience, I have found Unity Connection database extremely sensitive and does not tolerate any power shutdown or any network issues compared to their CCM cousins.
Hence in my humble suggestion, it would be far less painful and effortless to rebuild the Subscriber.
I have had my share of restless and sleepless nights (with TAC help) to rebuild a broken database replication or recover from a database corruption.
Tend to agree with that Wilson. +5
Please remember to rate useful posts, by clicking on the stars below.
Thanks for the reply.
in my situation a rebuild would be the last option and from what I can see the dbreplication is working fine I can make changes on the PUB and it will show up on the SUB and I can delete things from the SUB and they will be removed from the PUB. So I don't really know where to go from here and how to get rid of these error messages as far as the cluster talking to each other properly.
j4lvarad0
Did you find a solution to your problem?
I'm having the same issue after doing a backup restore on the PUB.
No, I still have not been able to solve this issue I am at the point of taking the advice in this post and just rebuilding.
We have a same scenario, where the CUC Version: 10.5.
NOTE: checked, the DBreplication on PUB its happening successfully (but still the below alert was seen on SUB)
10:41:24.768 |17539,,,SRM,3,<CM> Command: /opt/cisco/connection/bin/db-replication-control status icb0003 execution completed abnormally. Error number: 255
10:41:25.441 |17539,,,SRM,3,<CM> Command: /opt/cisco/connection/bin/db-replication-control status icb0006 execution completed abnormally. Error number: 255
Any update/ suggestions will be highly recommended
