Cisco Voice Gate way
abed.albouji
Any body have the wiring connectivity between the Enhanced Voice modules , EVM and the BLACKBOX Patch panel. I need the wiring diagram and Also to check what we need exactly for 48 FXO ports EVM modules on the 3945 Voice Gate Way.
11 Replies 11
paolo bevilacqua
As with all Cisco products, the hardware pinout is in the documentation.
For 48 FXS ports you need 2x EVM cards, 4x EM3 daughtercards, and a PVDM3-64.
abed.albouji
This is my Configuration for the Gw:
CISCO3945-V/K9Cisco 3945   Voice Bundle, PVDM3-64, UC License PAK
EVM-HD-8FXS/DIDHigh density   voice/fax extension module - 8 FXS/DID
EM-HDA-6FXO6-port voice/fax   expansion module - FXO
VIC2-4FXOFour-port Voice   Interface Card - FXO (Universal)
PVDM3-64U128PVDM3 64-channel to   128-channel factory upgrade
SM-NM-ADPTRNetwork Module   Adapter for SM Slot on Cisco 2900, 3900 ISR
PWR-3900-AC/2Cisco 3925/3945 AC   Power Supply (Secondary PS)
CAB-ACAC Power Cord (North   America), C13, NEMA 5-15P, 2.1m
S39UK9-15104MCisco 3925-3945 IOS   UNIVERSAL
PWR-3900-ACCisco 3925/3945 AC   Power Supply
3900-FANASSYCisco 3925/3945 Fan   Assembly (Bezel included)
C3900-SPE150/K9Cisco Services   Performance Engine 150 for Cisco 3945 ISR
ISR-CCP-EXPCisco Config Pro   Express on Router Flash
MEM-3900-1GB-DEF1GB DRAM   (512MB+512MB) for Cisco 3925/3945 ISR (Default)
MEM-CF-256MB256MB Compact Flash   for Cisco 1900, 2900, 3900 ISR
SL-39-IPB-K9IP Base License for   Cisco 3925/3945
SL-39-UC-K9Unified Communication   License for Cisco 3900 Series
CON-SNT-3945VSMARTNET 8X5XNBD Cisco 3945 Voice Bundle, UC License PAK
CISCO3945-V/K9    Cisco 3945 Voice Bundle, PVDM3-64, UC License PAK    1
EVM-HD-8FXS/DID    High density voice/fax extension module - 8 FXS/DID    4
EM-HDA-6FXO    6-port voice/fax expansion module - FXO    8
VIC2-4FXO    Four-port Voice Interface Card - FXO (Universal)    4
PVDM3-64U128    PVDM3 64-channel to 128-channel factory upgrade    1
SM-NM-ADPTR    Network Module Adapter for SM Slot on Cisco 2900, 3900 ISR    4
PWR-3900-AC/2    Cisco 3925/3945 AC Power Supply (Secondary PS)    1
CAB-AC    AC Power Cord (North America), C13, NEMA 5-15P, 2.1m    2
S39UK9-15104M    Cisco 3925-3945 IOS UNIVERSAL    1
PWR-3900-AC    Cisco 3925/3945 AC Power Supply    1
3900-FANASSY    Cisco 3925/3945 Fan Assembly (Bezel included)    1
C3900-SPE150/K9    Cisco Services Performance Engine 150 for Cisco 3945 ISR    1
ISR-CCP-EXP    Cisco Config Pro Express on Router Flash    1
MEM-3900-1GB-DEF    1GB DRAM (512MB+512MB) for Cisco 3925/3945 ISR (Default)    1
MEM-CF-256MB    256MB Compact Flash for Cisco 1900, 2900, 3900 ISR    1
SL-39-IPB-K9    IP Base License for Cisco 3925/3945    1
SL-39-UC-K9    Unified Communication License  for Cisco 3900 Series    1
CON-SNT-3945V    SMARTNET 8X5XNBD Cisco 3945 Voice Bundle, UC License PAK    1
One would need to check config against user requirements, that a Certified Cisco Partner job.
Iam not asking about cisco configuration.
Iam asking about blackbox accessories.
As mentioned before. All needed information is in the documentation.
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/exvoimod.html
Please remember to rate useful posts clicking on the stars below.
Dear Paolo
The PN is mentioned , I know that. My question is how many BLACKBOX needed ? and how many cables needed? And how they will be connected . I mean the connection diagram.
By the way Iam a pre-sales Engineer in a gold partner .
Check document linked above.
Dears
Kindly anybody can advice how is this connectivity and how many panels needed.?
Have you read the very clear document above ?
Four (4)
