IP Telephony and Phones
Labels
Hi All,  I Have Create Skype sip accout, and follow some doc to configure CME to regsiter, but fail, ask for help.Router config:sip-ua credentials username 99051000154290 password 7 033E6D063E210F67543A3427161303 realm sip.skype.com authentication u...
Resolved! C2911-CMESRST/ K9
I am configuring the components of a telephony solution using CME. Using QPT to make the config, it gives me the following voice gatewayC2911-CMESRST/K9                        (2911 UC Bundle w/PVDM3-16,FL-CME-SRST-25, UC License PAK) Down the list I...
Hi,How do I enable QOS on an Etherchaneel between A Cisco 3560 and A Cisco3750GConfiguring Auto QOS clearly not allowed after putting the interface in a port-channelThe Port-channel interface has no auto or mls optionsConfiguring auto QOS on the inte...
Resolved! Confused on Cube
HiI wanted to know can someone point me in the right direction on Cisco cube as far as any type fo diagrams or documention.The company I work has a company that they bought and they have IP overlap and they were told that they should invest in the Ci...
Hi,First of all, go easy on me...I'm not the most proficient when it comes to Cisco telephony, and CME in particular...and for Cisco routers/switches too.  I can get around in them and do common things, but once you dive deep into technical details a...
voip7372 by Level 4
  • 10798 Views
  • 26 replies
