Cisco Voice Gateway replacement
rasevedo65
Hello , does cisco offer another analog telephony device that would replace the VG204 gateways.? We would like to replace the ones that are curently being used since they no longer are supported. Thank you
johnd2310
Level 8
Level 8
According to the following link you should get the VG400 to replace VG204
https://www.cisco.com/c/en/us/products/collateral/unified-communications/vg-series-gateways/select-vg202xm-analog-voice-gateway-eol.html
John
**Please rate posts you find helpful**
