Cisco Voice Gateway VG310 configuration
Hope you are doing good. I have a question to ask.
Can you configure a Cisco voice gateway for example VG310 to allow only analog phones to communicate with each other and to the PSTN without adding CUCM or CME?
Aristide
10 Replies 10
Ayodeji Okanlawon
You should be able to configure them using h323 and that will not require CUCM or CCME.
Please rate all useful posts
Thank you Ayodeji,
Can you give me a sample example for configuration with H323?
Aristide
Hi try this..
dial-peer voice 1002 pots
 destination-pattern 1052 (1052  should be the analogue line attached to this port)
 port 1/0/0
dial-peer voice 1003 pots
 destination-pattern 1021 (1021  should be the analogue line attached to this port)
 port 1/0/1
Thank you,
I can configure also a BRI card in a VG310?
Aristide
Yes you can,
Supported Voice Interface Cards and Voice WAN Interface Cards
The EHWIC slot on the Cisco VG310 and Cisco VG320 chassis supports the following VICs and VWICs:
    Cisco VIC3-2FXS/DID
    Cisco VIC3-2FXS-E/DID
    Cisco VIC3-4FXS/DID
    Cisco VIC3-2E/M
    Cisco VIC2-2FXO
    Cisco VIC2-4FXO
    Cisco VWIC3-1MFT-T1/E1
    Cisco VWIC3-2MFT-T1/E1
    Cisco VIC2-2BRI-NT/TE
Thank you Sir.
Have a good day.
Aristide
You are welcome. Dont forget to rate the posts...:)
I have forgot one thing tomorrow. Can we configure this features below in VG310 without adding a CUCM or CME?
(Call forward all, Call forward busy, Call forward cancel, Call forward no answer, Call hold or resume, Call pickup group, Call pickup local,Call transfer blind, Call transfer consultative, Call waiting, etc...)
Aristide
No you cant
ok we must adding cucm or ccme.
Thanks a lot for your reply. Have a good day.
Aristide
