Cisco Voice SIP - Error 4404
brian.vanoy
We had some numbers relocated from a PRI circuit as VTNs on a SIP trunk and began to received Error 4404 at our outside interface when placing calls to the numbers.  We programmed the dial-peer (23) into the router, and have never had an issue with this before with any of the other numbers, including: 703, 304, 571.
Can anyone see a problem in the config below.. The telco rep said our outside interface was rejecting the calls.
voice service voip
address-hiding
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol pass-through g711ulaw
h323
h225 display-ie ccm-compatible
modem passthrough nse codec g711ulaw
sip
bind control source-interface GigabitEthernet0/0
bind media source-interface GigabitEthernet0/0
early-offer forced
midcall-signaling passthru
sip-profiles 100
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice class sip-profiles 100
 request INVITE sip-header Allow-Header modify " UPDATE, " " "
 request REINVITE sip-header Allow-Header modify " UPDATE, " " "
 response 180 sip-header Allow-Header modify " UPDATE, " " "
 response 200 sip-header Allow-Header modify " UPDATE, " " "
voice translation-rule 1
 rule 1 /^9/ //
voice translation-profile outbound
 translate called 1
voice-card 0
 dsp services dspfarm
 description *** MPLS LINK ***
 ip address 64.x.x.x 255.255.255.252
 duplex full
 speed 100
 service-policy output MPLS-QOS
interface GigabitEthernet0/1
 ip address 192.168.x.x 255.255.255.0
 ip flow ingress
 duplex auto
 speed auto
 h323-gateway voip bind srcaddr 192.168.x.x
dial-peer voice 1 voip
 description *** Route Calls to CallManager ***
 preference 1
 destination-pattern [0-8]...
 voice-class codec 1
 voice-class h323 1
 session target ipv4:192.168.x.x
 incoming called-number ....
 dtmf-relay h245-alphanumeric
 ip qos dscp cs5 media
 no vad
dial-peer voice 2 voip
 description Outbound Local Calls to Paetec
 translation-profile outgoing outbound
 preference 2
 destination-pattern 9[2-9]......
 voice-class sip early-offer forced
 voice-class sip profiles 100
 session protocol sipv2
 session target ipv4:172.x.x.x
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 3 voip
 description Outbound Long Distance Calls to Paetec
 preference 2
 destination-pattern 91[2-9].........
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 4 voip
 description Outbound International to Paetec
 preference 2
 destination-pattern 9011.T
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 5 voip
 description Outbound 911 Calls to Paetec
 preference 2
 destination-pattern 911
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 6 voip
 preference 2
 destination-pattern 9911
 dtmf-relay rtp-nte
 codec g711ulaw
dial-peer voice 20 voip
 voice-class codec 1
 session target sip-server
 incoming called-number 703.......
 dtmf-relay rtp-nte
 no vad
dial-peer voice 21 voip
 voice-class codec 1
 incoming called-number 571.......
 dtmf-relay rtp-nte
 no vad
dial-peer voice 10 pots
 destination-pattern 7033650460
 port 0/0/0
dial-peer voice 100 voip
 preference 2
 voice-class codec 1
 voice-class h323 1
 no vad
dial-peer voice 22 voip
 voice-class codec 1
 incoming called-number 301.......
 dtmf-relay rtp-nte
 no vad
dial-peer voice 23 voip
 voice-class codec 1
 incoming called-number 904.......
 dtmf-relay rtp-nte
 no vad
sip-ua
 credentials username 571xxxxxxx password 7 xxxxxxxxxxx realm none
 no remote-party-id
 retry invite 2
 retry register 10
 timers connect 100
 registrar ipv4:172.x.x.x expires 3600
 sip-server ipv4:172.x.x.x
 host-registrar
call-manager-fallback
 max-conferences 4 gain -6
 transfer-system full-consult
 timeouts interdigit 5
 ip source-address 192.168.x.x port 2000
 max-ephones 30
 max-dn 144
Jonathan Unger
Level 7
Level 7
Hi There,
A couple things:
1. Can you please post the following debugs for a failed call? Be sure to disable console logging before running any of these. If it is a really busy gateway you can do these during a period of low activity.
- debug ccsip messages
- debug voip dialpeer inout
- debug voip ccapi inout
2. Are you trying to route these inbound calls to CUCM, or back out to your sip-ua defined "sip-server"? It isn't too clear based on your dial-peers where you would like these calls to go.
Jonathan,
Thank you for taking the time to respond to my inquiry.
1. Unfortunately, we had to move the numbers back to the PRI temporarily to keep them operational, so a failed call with the debug I assume isn't an option at this point to gain any clarity.
2. Correct, they are inbound calls being routed to Call Manager, and I assumed like my other dialing peers, the "session target sip-server" would suffice for the routing once the numbers were allocated to the SIP trunk itself.
Thanks, Brian
Hi Brian,
Cisco VGWs operate on the principal of inbound and outbound dial-peer matching, meaning that there must be an inbound dial-peer and an outbound dial-peer for each leg of the call.
In this case it looks like you have a valid inbound dial-peer (23), But no valid outbound dial-peer to CUCM.
Your other incoming DIDs in area codes 703, 304, and 571 are working almost by fluke because of dial-peer 1.
preference 1
The destination pattern states that the number must start with a number between 0 and 8 and have 3 or more digits after.
The other DIDs start with the number 7,3, and 5, so they will match that destination pattern and be routed to CUCM. If you wanted dial-peer 1 only to be good for 4 digits it would have to end with a $.
The new area code will not match dial-peer 1 because it starts with a 9 (not in range).
I would recommend creating a new CUCM dial-peer for the new set of DID's, here is an example:
dial-peer voice 999 voip
destination-pattern 904.......$
voice-class codec 1
voice-class h323 1
session target ipv4:192.168.1.1
no vad
For more information on dial-peer matching on Cisco VGWs check out the following link:
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/cube-dp.html
Please let us know if this helps!
