Cisco voicegateway
miskoolak
I have MD110 as pbx. the MD has E1 link from telco to provide outside calls.
I defined in my VG "9" for going out .
when a user dial 9 two problem occures:
1) the user hears some kind of noises!!
2)the user can not here dial tone
please help
14 Replies 14
paolo bevilacqua
What exactly is the VG and how is connected to rest of the other things ?
The VG is cisco 2821 and is connected via E1 to pbx.
Could you upload the configuration for better understanding
where are you calling with "9" ?
hi
here is my config:
dial-peer voice 10 pots
port 0/2/0:15
forward digit all
destination-pattern 9
when I dial i can not here PSTN dial-tone from pbx.also the important thing is that when I dial 9 no time slot activation happend
i hear just noise some kind "shshshshsh"
in this point i can dial my number after finishing my dial the connection established.
but i want to hear PSTN dial tone after dialing 9
thank you
Hi, you are not calling any number because the 9 is absorbed being it pots DP. Add "no strip-digit" and PBX should connect you to PSTN. You can also do a DP like 9.....T this way you can call directly, no need to wait for dialtone.
Please rate post if it helps!
Hi again
its mandatory to hear pstn dialtone.
please guide me to hear PSTN dialtone.
waiting for you reply
As mentioned before, configure as indicated and you should have dialtone from PSTN.
hi
I will do your command and will let you know
Dear freind
i provide my your command but still can not hear PSTN dial tone
can you provide me something else?
regards
Are you using CM or CME ? Sometime you can configure "secondary dialtone" to emulate PSTN dialtone.
there is no any CM or CME on my network
there is just ericcson MD110 and cisco gateway (CISCO 2811)
we are trying to make call from PBX extentions.
but still we can not here PSTN dial tone!
its very importatnt..
if you need further information let me know.
thank you for following up
The 2821 is connected to both PBX and PSTN ? And to for which purpose ?
Please specify with a diagram all that is connected as requested before.
here is diagram
PSTN---PBX1----Router----IP-----Router----PBX2--users
