Cisco VOIP Gateway with Multiple Number (voice port)
a.aljiledi
Hello everyone,,
i have Cisco 2900 running as a VOIP gateway that connected to E1 interface that provide ISDN service ,, and connected to the 3cx server as SIP gateway,,
i need to add another E1 interface to use another voice number ,, so how i can configure 2 voice port and 2 sip gateway to the 3CX ,, and how i can route the calls ,,,
the phone number that already running = 3660009  & short number = 0901
the new phone number that = 3660010
the current configuration for 1 voice port on the following :
controller E1 0/1/1
pri-group timeslots 1-31
interface Serial0/1/1:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice voice
isdn calling-number 3660009
voice-port 0/1/1:15
connection plar 0901
dial-peer voice 3 pots
description Outgoing calls to PSTN
destination-pattern 09........
port 0/1/1:15
forward-digits all
dial-peer voice 1 pots
description incoming calls from PSTN
incoming called-number .
direct-inward-dial
dial-peer voice 4 voip works
description Outgoing calls to 3CX
destination-pattern 0901
signaling forward none
session protocol sipv2
session target ipv4:10.10.10.1
voice-class sip rel1xx supported "100rel"
no voice-class sip pass-thru content unsupp
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 5 pots
description Outgoing calls to PSTN-Service
destination-pattern 1300
port 0/1/1:15
forward-digits all
dial-peer voice 2 voip
description incoming calls from FREEPBX
translation-profile incoming AutoAttendant
incoming called-number .%
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
no vad
gateway
timer receive-rtp 1200
sip-ua
no remote-party-id
retry invite 3
retry response 3
retry bye 3
retry cancel 3
timers trying 1000
sip-server ipv4:10.10.10.1
the configuration on 3CX,,,
Trunk Port defined the Router IP and Port  only,,,
waiting for any advice,,,
You should not need to create an additional trunk in the 3CX system for this. Based on the shared information I think that something similar to this should do the trick for you.
controller E1 0/1/?
interface Serial0/1/?:15
no ip address
encapsulation hdlc
isdn calling-number 3660010
voice-port 0/1/?:15
connection plar <number you want to use for PLAR>
voice class uri 3CX sip
host ipv4:10.10.10.1
host ipv4:<any other IP that the 3CX system might have>
voice class e164-pattern-map 1
description E164 Pattern Map for called number to 3CX
e164 0901
e164 <any other directory number that you have on 3CX that you want to send calls to from the gateway>
voice class server-group 1
ipv4 10.10.10.1 preference 1
ipv4 <any other IP that the 3CX system might have> preference 2
description Inbound calls to 3CX
voice class sip-options-keepalive 1
description Used for Server Group SIP OPTIONS PING
dial-peer voice 30 pots
destination-pattern <any pattern to use for your new E1 for outbound calls to PSTN>
port 0/1/?:15
forward-digits all
!As an option to add dial-peer 30 you could reconfigure dial-peer 3 to use a trunk group instead of individual a port
no destination-pattern 0901
destination e164-pattern-map 1
no session target ipv4:10.10.10.1
session server-group 1
voice-class sip options-keepalive profile 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
description Incoming calls from 3CX
no session target ipv4:10.10.10.1 !This is an outbound dial-peer setting, no need to have on an inbound dial-peer
no incoming called-number .%
incoming uri via 3CX !Better match than what you had before with incoming called-number
dtmf-relay rtp-nte
codec g711ulaw
no vad
All this depends on the version of IOS you have, for your gateway model my recommendation would be to use version 15.7(3)M8.
For additional in-dept information on IOS call routing have a look at this marvelous document.
Response Signature
