Cisco Webex Connect(Jabber) errors
Murali Dharan
Hi All,
I am very new to Cisco webex connect, I am creating this descussion just to increase my knowledge.
Having the following questions.
1. Normally contacts and meetings options are availabe in cisco webex connect window, how to bring phone option addtionally as a 3rd option(Please check the attachments).
2. CIPC is already installed in laptop, if we install Cisco webex connect in the same laptop whether it will bring any problem with cisco webex connect?
Thanks & Regards,
Murali
Jonathan Schulenberg
You need to configure the CUCM information in Org Admin. Additional information is available in the WebEx Connect Administration Guide, Understanding Cisco Unified Communications Integration section.
They can coexist but I wouldn't suggest running them at the same time; you'll get incoming call alerts on both.
