Cisco Webex URI Dialling
I want to buy webex. If I buy webex with URI feature enabled. Can I dial into a conference using 3rd party VCON devices like polycom group series?
George Sotiropoulos
Yes this is totally possible. Participants will be able to join in by:
-Webex Web Service (from their PC) "Join Webex Meeting"
-By any video system or application (this is what you are asking, see example)
Dial 945147777@companyname.webex.com
You can also dial 62.109.219.4 and enter your meeting number.
-By Phone (Depending on your purchase you can have Global Call-in Numbers)
You may also check the following post:
https://community.cisco.com/t5/collaboration-voice-and-video/cisco-webex-meetings-overview/ta-p/3648888
Hope this helps,
George
Hope the above helps,
gsotirop
George Sotiropoulos
Hope this helps,
George
gsotirop
Dear George,
Thanks for the info.
Raj
