08-14-2017 06:01 AM - edited 03-17-2019 11:00 AM
Hi again,
i tried a firmware upgrade on my phone to version 1.4.8.4 which I downloaded from cisco but it seems not to work.
After I choose the Tar-file from my pc it starts to upgrade and when it should be finished it starts again with same procedure.
it looks like a loop. After I watch on the phone it´s still the old firmware. I tried this with connected USB-cable and without with same result.
what is the problem? see pics
08-14-2017 02:00 PM
Maybe the phone is configured in CUCM to load the old IOS.
08-15-2017 12:07 AM
Thanks, can you please explain further which settings in the CUCM we have to change.
At a first look I couldn´t find anything except the "phone load name" which says CP7925G-1.4.1SR1
08-15-2017 02:50 AM
That is what I'm saying.
You're trying to manually upgrade the phone firmware to 1.4(8), however, the phone-specific configuration found in CUCM shows the phone must load 1.4(1)SR1. So the phone boots up with 1.4(8) and then joins CUCM. CUCM configuration forces the phone to downgrade to 1.4(1)SR1.
If you want to upgrade the firmware of the phone, change the settings on CUCM and make sure the firmware files are found in CUCM. And don't forget to restart the TFTP server.
