11-16-2009 12:27 AM - edited 03-18-2019 10:50 AM
Is there a command to see how the callmanager was booted? from power failure or from a clean shutdown?
thanks,
JH
11-20-2009 02:21 PM
No, there is no CLI command to get any of that info
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
11-22-2009 11:34 PM
OK,
Should be implemented though!!!
This is critical!
Bye,
Jan
11-23-2009 06:11 AM
Get in touch with your AM if you want to submit a PER for that
java
11-23-2009 06:41 AM
Thanks, I will
Jan
11-23-2009 07:09 AM
Although there's no CLI command for that, as Java said, I think it could be workaround by researching performance counters, alerts, traces and audit logs from the RTMT to determine the cause of a callmanager restarted.
Maybe Java can confirm whether this is feasible.
Hope it helps,
- Adrián.
11-23-2009 07:25 AM
Good thinking, I shall also have a look at this.
Jan
