03-30-2013 01:29 PM - edited 03-16-2019 04:32 PM
Hi Akon as you know, we recently configured CUBE (ip2ip) gateway for the new SIP link but caller-id is not working properly. It works for some outbound calls and does not work for some outbound calls.
I noticed a pattern when it CLI works and and when it doesn't work in the ccsip debug. I have attached ccsip messages debug results. Please help to figure out issue.
Solved! Go to Solution.
04-05-2013 11:01 AM
Hi Aok,
Shall I send you more logs or the one I posted above are ok?
04-05-2013 11:23 AM
Muhammad,
I dont know what to say. It works on one CUBE and diesnt work on the other, This cant be config related. It only affects mobile numbers. Please remove the anonymous config and use the config on CUBE-A...dont forget to change the ip address...Tell your provider what you are experiencing...This has to be their issue
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-05-2013 12:22 PM
Hi Aok,
I also think its a problem at service provider end. I have logged an incident see whay they reply. Will let you know what they reply. Thanks for your help
04-08-2013 12:34 AM
Hi Aok,
Yeah I do agree with you, I have logged with service provider, see what they responce back.
04-08-2013 12:19 PM
Hi Aok,
Just got reply from the service provider regarding this issue.
The discrepancy between the two endpoints is due to the firmware version differing on each on the SBC’s that the endpoints reside.
Going forward, I can only suggest you send a P-Asserted Identity header with ‘Privacy: Full’, alternatively
So instead of send Remote Party ID header with privacy full they are demanding to send P-Asserted Identity header with Privacy Full
04-08-2013 12:38 PM
Ok..
Please disable remote-party id and try this profile
voice class sip-profiles 3
request INVITE sip-header P-Asserted-Identity "<>" "<>;privacy=full">>
04-09-2013 03:18 AM
Hi Aok,
CLI witheld issue has not been resolved yet, yesterday when I tested P-Asserted sip profile it was actually going out from the CUBE-A router instead of CUBE-B.
I have attached ccsip messages and ccapi inout debug. I can see this error "Reason: Q.850;cause=127" Also in the log file I can also see in log
P-Asserted-Identity: "Muhammad Sarwar" <44043>;privacy=full44043>
Is that service provider issue?
voice class sip-profiles 4
request INVITE sip-header P-Asserted-Identity modify "<>" "<>;privacy=full">>
dial-peer voice 2 voip
description *** Outbound LANDLINE calls to ITSP ***
destination-pattern 0[1-37].........
session protocol sipv2
session target sip-server
voice-class codec 1
voice-class sip asserted-id pai
voice-class sip profiles 4
dtmf-relay rtp-nte
ip qos dscp cs4 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 3 voip
description *** Outbound 0845-0870 calls to ITSP ***
destination-pattern 0[8][047][0458]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
04-09-2013 03:25 AM
Ok,
Looks like the P-Asserted-Identity header is not properly formatted..
Your provider dosent like it...I will look and see how it should be formatted
*Apr 9 09:53:20.112: //3357/97437D000001/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 400 Bad Request
Via: SIP/2.0/UDP 10.60.34.106:5060;branch=z9hG4bKC55C5B
From: "Muhammad Sarwar" <44043>;tag=1797B4B0-E1F44043>
Call-ID:
24D16B65-A03211E2-AAFFB442-D4C147C4@10.60.34.106
CSeq: 101 INVITE
To: <07967999481>;tag=3574490123-86295507967999481>
Content-Length: 0
04-09-2013 04:37 AM
NB: syntaxt error in the previous post, so I deleted it..Use this one..
I looked into the RFC for P-Assreted-Identity and it looks like you need a seperate Privacy field to use Privacy with PAI..
So lets give this a go..
on CUBE B
Please remove the sip proflie for the P-Assersted -Identity..add the below to the profile..
request INVITE sip-header Privacy add "Privacy: id"
Please check your CLI..if the Privacy header is in the logs and it still doesnt work then try
request INVITE sip-header Privacy add "Privacy: full"
Please test again and send me debug ccsip messages...
Pls make sure you remove the previous profile..
Leave all the other configs
04-09-2013 04:59 AM
Hi Aok,
Fantastic Its working now, I tried the privacy:id in the header and that worked. I can also see in the log Privacy: id
Once again bundle of thanks for your help
04-09-2013 06:54 AM
Hi Aok,
While testing SIP trunk I noticed we cannot dial anymore 8 digit numbers without STD code for example 976XXXXXX. To resolve that I added another dial-peer and also added another translation rule to add STD code.
But I dont know where should I apply this, I mean in which direction incoming or outgoing?
for example user dial a number 976123456 it should strip 9 and add 024 infornt of that
voice translation-rule 25
rule 1 /^9\(........\)/ /024\1/
dial-peer voice 4 voip
description *** Outbound Without STD calls to ITSP ***
destination-pattern 76......
voice-class codec 1
dtmf-relay rtp-nte
no vad
04-09-2013 07:05 AM
Here you go..
voice translation-profile STD
translate called 25
destination-pattern 976...... (this must match the dialled number before stripping the 9)
translation-profile outgoing STD
04-09-2013 07:40 AM
Hi Aok,
I have applied this config but its not working. One thing more we are striping 9 on router level not from the CUCM. When I see the logs I can see 9 is not stripping off and also cannot find Outgoing dial-peer
I have attacehd logs
voice translation-rule 100
rule 1 /^9/ //
voice translation-profile STRIP9
translate called 100
dial-peer voice 101 voip
description *** Inbound Calls from ITSP ***
translation-profile incoming STRIP9
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte
04-09-2013 08:22 AM
Please send me your updated sh run again (attach it here)
04-09-2013 10:31 AM
Hi Aok,
Did you find any thing suspicious in a config?
