09-27-2012 08:42 AM - edited 03-16-2019 01:25 PM
Hi Netpro
I have this lab, whit CUCM 8.5(1)
Site A
Publisher 10.0.0.10
TFTP Server
Site B
Subscriber 20.0.0.10
TFTP Server
For the routing i have a 3650 with 2 vlan simulating L3 routing intersite. and the DHCP server is a Windows 2003 server with option 150 configured.
In the DHCP Server TFTP options is:
DHCP Scope site A
Network 10.0.0.0/8
TFTP Option 10.0.0.10 20.0.0.10
DHCP Scope site B
Network 20.0.0.0/8
TFTP Option 20.0.0.10 20.0.0.10
If i register a phone in site A the phone works OK on the Publisher, and if register phone in site B the phone register OK on the Subscriber, but if publisher or subcriber fail, the phones don't register in the backup server
All the services is active and running the publisher and subscriber and the database is OK. The device pool for the site, one have publisher first and the other have the subscriber first.
Any idea?
09-27-2012 08:48 AM
What is the CUCM Group configured like? Does it list both servers?
Chris
09-27-2012 08:52 AM
Yes
CUCM Group for site A have Publisher and Subscriber, and the CUCM Group for site B have Subscriber and Publisher.
09-27-2012 08:55 AM
Are you referencing the servers by hostname or IP addresses?
What if you assign site A group to site A DP, which server does it register to?
When you browse the IP address of the phone, does it list both servers as CM servers?
What is the phone status log show?
Chris
09-27-2012 09:19 AM
The server reference is for IP.
Don't care wich is the order in CUCM Group the first TFTP set in the DHCP server the phone register there.
When browse the phone config in the TFTP show both server, but in the config Unified CM only see one CUCM.
Until server TFTP predetermined
09-27-2012 09:30 AM
What if you assign site A group to site A DP, which server does it register to?Don't care wich is the order in CUCM Group the first TFTP set in the DHCP server the phone register there.
That is not the way it works, the CM group determines which server the device registers with not TFTP, it it registers with TFTP then that means the config file is not downloaded.
By browsing phone's IP I meant, enter the IP address of the phone in web browser and go go to Network Configuration --> locate CallManager 1 and CallManager 2, what shows up?
to view phone log press Settings --> Status on the phone or access it from the phone's web site per above
Chris
09-27-2012 02:05 PM
Chris
Thanks so much for your help finally the problem is a name resolution... layer 8 problem.The publisher server was sending hostname not IP address, with your help can see the problem. Now the configuration is correct and have HA.
Kind regards.
