CM 6.1, SIP Trunk Provider
CiscoRTL99
Hello guys,
I spend the last hours to try to connect my CM to my Trunk SIP provider (ovh),
And I just don't understand how to do that,
please help me !
6 Replies 6
kaja_2kj3
     Please follow the call flow as below,
CUCM---sip---CUBE--sip----ITSP
Also please see the link below,
https://supportforums.cisco.com/thread/2219782
Please rate if this this helps
Why I have to configure the router for that ?
I mean when I configure an asterisk with a SIP provider I just add the line:
register => 003397XXXXXXX:password@sip.ovh.fr
and nothing more, I don't understand why it's seem so complicate to connect CM to a SIP provider ?
You Need a Cisco Cube to achieve this because CUCM doesn't support authenticated SIP Trunk registration.
...and because CUCM is not Asterisk..
Carlo
Please rate all helpful posts
"The more you help the more you learn"
Please rate all helpful posts "The more you help the more you learn"
okay, with the most recent version of CM, is that possible to do without CUBE ?
No, we still recommend you to use a CUBE since CUCM can't do the above as mentioned by Carlo
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
ok thx
