12-27-2011 09:41 AM - edited 03-16-2019 08:42 AM
I have installed CUCM 7.0 in VMWare with 100 GB HDD and 1024 MB RAM. I have a CUCM 6.0 running absolutely fine on the same machine. It seems like that I have intermittent network connectivity issues. When I setup a continuous ping I see that there are a lot of packets being dropped at regular intervals. I do not see the processing being stretched at all so not sure if this is an issue with the hardware. I have run CUCM 6.0 and UCCX 7.0 at the same time (2 VMWare machines).
Can anyone please guide me in this regards.
Thanks.
12-27-2011 10:19 AM
Imran,
Intermittent Ping drops as expected as CUCM does that on purpose, I am sure you can find many threads on this topic here.
HTH,
Chris
12-27-2011 10:34 AM
Hi Chris,
Thanks a lot for the quick response. It seems like that the GUI is not accessible at that time. I tested it on CUCM 6.0 and the ping responses are continuous. I tried installing CUCMBE 7.0 as well and I am getting the same issue. Due to this issue, I can't really work with that machine and really need to work on 7.0.
Imran.
12-27-2011 06:28 PM
yes, Chris is right. please check your netconfig of VMWARE, you can find vmnetcfg.exe in your VMWARE installation directory, use this tool to check.
good luck!
kaitao
12-28-2011 09:55 AM
Hi Kaitao,
Thanks a lot for the reply. Can you guide a bit more about the netconfig as how to use it and where to find it as I cant find it and a quick google search didn't help either.
Thanks.
