CM reports & a few questions
kuzmichius
Hi guys,
I was wondering if it is possible to extract information how many devices are currently in use or how many directory numbers are set up. For example there are internal numbers set  like 8020,8021, 80XX, in another country 20xx, in the third 30xx numbers.... I would like to see some kind of report what IP numbers are used at the moment and what are free if that makes sence.
Rob Huffman
Hi Marius,
One of the better reports comes from this section of CUCM
From CUCM admin Call Routing > Route Plan Report and once it loads
up look at the top right hand corner of the page for "View in File" this will allow
you to save a copy in .csv format
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
that's perfect ! thank you.
