Configuration of MOH in CUBE
V.Naveen Kumar
I tried configure moh in cube
# en
# ip multicast-routing
# exit
# ccm-manager music-on-hold
# telephony service
# moh <xx>.au
# moh multicast 239.1.1.1 16384
Conf.  multicast MOH in CUCM
add to MRG and then to MRGL
add to device pool
But insite call moh is working fine but off site call like PSTN r other site person call..
they cannot hear moh instead of that their is only silence..!!!'
help out... for this issue..!!
You need to have the route statement on the multicast line in telephony-service to get MOH to both internal and PSTN.
Below is an example
interface Loopback0
ip address 10.10.110.3 255.255.255.255
telephony-service
ip source-address 10.10.202.1 port 2000
moh music-on-hold.au
  multicast moh 239.1.1.1 port 16384 route 10.10.202.1 10.10.110.3
The second address in the route is a loopback IP, that is used to get the MOH to the PSTN caller. This is only used local to the VGW, ie it doesn't need to be routed in the network.
Apart from this you also need to have at least on ephone-DN and ephone defined under telephony-service to get MOH to work.
See more at this link,
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html#wp1101505
Please remember to rate helpful responses and identify helpful or correct answers.
Response Signature
