CM upgrade from 6 to 10.5
janischan
My customer is currently using CM6.1 with 1000 x  79xx phones, we are proposing upgrade to 900 x enhance license and 100 CUWL license, is below part# correct?
MIG-CUCM-USR-A
MIGB-UCM-UWL-STD
JC
Hi ,
 I recommend to use the License Count Utility (LCU).
 This way you can check the correct license.
Hope this helps.
for UCL Enhanced, part codes are fine.
further,for CUWL Standard, MIGE-UCM-UWL-STD , UC-8.x or earlier and UCAPPS-SW-10.x-K9 are the PArt Codes.
You can also get in touch with Cisco Partner for more details.
regds,
aman
