10-10-2008 01:40 AM - edited 03-15-2019 01:51 PM
Hi!
When I call to the voice mail I get a busy signal back. It has worked before.
The event viewer log from the Exchange server displays the following message: "the unified messaging server rejected an incoming call with ID ......@x.x.x.x" Reason "Cannot find a valid UM IP Gateway for x.x.x.x..."
Any idea why is this happening? There has been some new configuration for the OCS installation.
Ana
10-10-2008 02:26 AM
I'm not a 2007 expert but found a relevant document on google. It might be worth checking the details here to make sure the IP address is correct in Exchange Management:
Hope this helps.
10-10-2008 03:41 AM
Are you sure that the UM IP Gateway is (still) configured in Exchange?
Is the dialplan okay?
10-13-2008 01:50 AM
Hi!
In Exchange it seems to be everything properly configured as in the CUCM!
I would like to do some further troubleshooting like for example have some logs. What do you advise? /var/log?
Meanwhile there is something that I've noticed that I'm not sure if could be the problem:
On the administration UI, âSystem ï Licensing ï License Unit Reportâ I've confirmed that the license file is uploaded but the status does not indicate Ready.
Best Regards,
Ana
