CM7 more than 144 VM ports, again
balitewiczp
Level 2
Level 2
Just bumped CM7 from 7.02.1000-18 to 7.02.2000-5, which I thought was also called 7.0.2a, and would give me more than 144 ports in CM7. Still cant configure more than 144. Am I missing something?
Rob Huffman
Hey Pete,
Did you open a TAC case for this? I'm just looking @ the Fixed-In versions and it doesn't show your newest build :(
Fixed-In
7.1(1.39000.91)
6.1(3.9901.72)
7.0(2.39000.41)
6.1(3.2102.1)
7.1(1.39000.114)
6.1(3.9901.91)
7.0(2.39000.59)
7.0(2.11003.1)
7.0(1.21022.1)
6.1(3.3190.1)
Maybe you can get one of the "listed" Fixed-In versions directly from them.
Just a thought,
Rob
From cisco TAC............
I consulted to my escalation point about it. They told me that the only available option is to configure 144 ports in the CUCM although the release notes say that is possible to configure 999 ports and the option to configure more than 144 ports maybe will be available on the 8.x release that does not have a release date yet.
Oh well, at least i got to run through an upgrade.
