06-08-2016 04:03 AM - edited 03-17-2019 07:09 AM
Hello
i have the following problem:
The users with sccp phones can pickup all the incoming calls.
The users with SIP phone CP-8841 cannot pickup calls from sccp phones.
Because the 10.5 CME does not support cp-8841 i have tried to work with "compatible" type 9971 and 8941.
In both situations can make and receive calls but it is not able to pickup from the other.
Below is some info from the configuration file:
voice register global
mode cme
source-address 192.168.1.1 port 5060
timeouts interdigit 3
max-dn 20
max-pool 10
load 7942 SCCP42.9-4-2SR1-1S
load 8941 sip88xx.11-0-1-11
load 9971 sip88xx.11-0-1-11
authenticate register
olsontimezone Europe/Athens version 2011h
time-format 24
date-format D/M/Y
mwi stutter
mwi reg-e164
call-feature-uri pickup http://192.168.1.1/pickup
call-feature-uri gpickup http://192.168.1.1/gpickup
voice register dn 1
number 802
allow watch
pickup-call any-group
pickup-group 1
name User1
label User1
voice register pool 1
busy-trigger-per-button 2
id mac DCCE.AAD0.1200
feature-button 1 PickUp
feature-button 2 GpickUp
type 8941
number 1 dn 1
cor incoming use11 default
presence call-list
dtmf-relay sip-kpml cisco-rtp sip-notify
username demo password demo
codec g711ulaw
no vad
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 1
sdspfarm tag 1 confdsp1
conference hardware
max-ephones 42
max-dn 192
ip source-address 192.168.1.1 port 2000
service dnis overlay
service dnis dir-lookup
timeouts interdigit 2
timeouts busy 30
timeouts night-service-bell 5
timeouts transfer-recall 10
system message Company
time-zone 26
time-format 24
date-format dd-mm-yy
voicemail 123
max-conferences 16 gain -6
call-park system application
call-forward pattern .T
moh enable-g711 "music-on-hold.au"
multicast moh 239.12.13.14 port 2000
transfer-system full-consult dss
transfer-pattern .T
secondary-dialtone 9
fac standard
create cnf-files version-stamp 7960 Jun 06 2016 07:23:12
ephone-dn 1 dual-line
number 801
pickup-group 1
label User2
description 801-User2
name User2
corlist incoming use10
ephone-dn 3 dual-line
number 803
pickup-group 1
label User3
description 803-User3
name User3
ephone 1
description === 801-User2 ===
mac-address DCCE.C561.6111
ephone-template 1
type 7942
button 1:1
ephone 3
description === 803-User3 ====
mac-address DCCE.C145.1230
ephone-template 1
type 7942
button 1:3
06-08-2016 04:33 AM
Can you try configuring the 8841 phone using the fast track method as CME 10.5 supports this model using fast track method.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme105spc.html
http://x-ccie.blogspot.in/2014/12/cisco-cme-fast-track-feature.html
Also confirm your cor config is fine.
Rajan
06-08-2016 05:40 AM
Thanks but which is the reference model i should use?
06-09-2016 05:39 AM
I create fast track below is the changes at the config
But still No pickup :(
voice register pool-type 8841
xml-config maxNumCalls 2
num-lines 2
description 8841 Cisco Phone_FastTrack
reference-pooltype 6941
mode cme
source-address 10.12.2.2 port 5060
max-dn 20
max-pool 10
load 6941 SIP69xx.9-2-1-0
id mac DCCE.C115.FE00
type 8841
number 1 dn 1
presence call-list
username ak password demo
dnd
codec g711ulaw
no vad
08-05-2020 07:17 PM
08-06-2020 06:22 AM
Yes it will be supported. not need to do fastback.
below link contains more details.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/requirements/guide/cme125spc.html
