01-26-2016 12:17 PM - edited 03-17-2019 05:37 AM
I was using CME version 8.1, and after updating the 7945 phones stopped working, what should I do?
I updating for use phones 7811.
Alexandre
Solved! Go to Solution.
01-26-2016 04:26 PM
This is kind of strage as you do not engouh phones registered or configured but received max-count limit. can please do one thing and check if there is acl or port is getting blocked. performed shut and no shut under the telephony if does not worked then perform below step
erase the configuration from 7945 phone erasing CTL and ITL > delete the configuration from CME of the ephone and ephone-dn > remove the max-ephone and max-dn and re-configured it again
and last no create and create cnf under telephony service.
000950: Jan 26 23:52:43.118: %CRYPTO-4-IKMP_NO_SA: IKE message from 200.170.138.209 has no SA and is not an initialization offer 000951: Jan 26 23:52:44.110: ephone-(2)[1] Register StationIdentifier DeviceName SEPF07816A3A318 000952: Jan 26 23:52:44.110: ephone-2[1/-1][SEPF07816A3A318]:stationIpAddr 10.10.1.2 000953: Jan 26 23:52:44.110: ephone-2[1/-1][SEPF07816A3A318]:stationIpv6Addr :: 000954: Jan 26 23:52:44.110: Skinny register (phones=0/0/21) REJECT from IP 10.10.1.2
000987: Jan 26 23:52:51.610: ephone-(1) Allow any Skinny Server IP address 10.10.1.1SEPF07816A3A682: Registration failed. Max phone count reached 000988: Jan 26 23:52:51.614: Failed SkinnyAssociatePhone for SEPF07816A3A682 tag 1 000989: Jan 26 23:52:51.614: Skinny register (phones=0/0/21) REJECT from IP 10.10.1.4 000990: Jan 26 23:52:55.018: TFTP: Looking for SIP_English_United_States/sp-sip.jar
01-26-2016 12:55 PM
what do you mean stopped working? Is phone un-registered, not able to make calls after upgrade . please share some detail
01-26-2016 01:00 PM
All the phones 7945 are UNREGISTERED after upgrade.
01-26-2016 02:14 PM
can you please post the show run from CME and also what is the firmware version of the phone is it 9.2 if not can you please try upgrading the firmware. also try collecting below
debug tftp events
debug tftp packets
01-26-2016 02:36 PM
01-26-2016 03:03 PM
can you manually bind the all file for 7945 load, seems like not finding the load file
also collect the below debugs again and show output
Show ephone registered
Show ephone unregistered
Debugs
debug ephone register [mac-address]
debug ephone keepalive
debug ephone state
debug tftp events
debug ip dhcp
debug ephone raw --> SCCP Messages
eg
tftp-server flash:SCCP75.9-2-1S.loads alias SCCP75.9-2-1S.loads
01-26-2016 03:57 PM
01-26-2016 04:26 PM
01-26-2016 04:40 PM
After procedure, just 2 phones Registered:
ephone-1[0] Mac:F078.16A3.A682 TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 22/17 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:9
IP:10.10.1.4 * 49773 7945 keepalive 22 max_line 2 available_line 2
Preferred Codec: g711ulaw
Lpcor Type: none
ephone-2[1] Mac:F078.16A3.A318 TCP socket:[2] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 22/17 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:1 caps:9
IP:10.10.1.2 * 49850 7945 keepalive 22 max_line 2 available_line 2
Lpcor Type: none
ephone-3[2] Mac:F0B2.E578.F95B TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:1 caps:0
IP:0.0.0.0* 0 Unknown 0 keepalive 0 max_line 0 available_line 0
Lpcor Type: none
ephone-4[3] Mac:7CE9.D3EC.391B TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
Lpcor Type: none
ephone-5[4] Mac:F078.16A3.A7D9 TCP socket:[-1] activeLine:0 whisperLine:0 UNREGISTERED
Lpcor Type: none
01-26-2016 04:47 PM
try configuring reset phones.
just remove ephone and add it back again. hope this will solve the issue. erase the CTL and ITL prior to that
