12-17-2015 05:25 AM - edited 03-17-2019 05:16 AM
Users at one single site are complaining of poor call quality, the MOS is in the high ones. Does everything look OK from the gateway side? Wondering if packets are already marked as EF coming in.
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(15)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 18-Jul-07 06:21 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
Router uptime is 6 weeks, 4 days, 1 hours, 36 minutes
System restarted at 07:49:25 CDT Fri Wed 16 2015
System image file is "flash:c2800nm-spservicesk9-mz.124-15.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2851 (revision 53.51) with 512000K/12288K bytes of memory.
Processor board ID
2 Gigabit Ethernet interfaces
24 Serial interfaces
1 Channelized T1/PRI port
4 Voice FXO interfaces
2 Voice E & M interfaces
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Router#show invenotyry
NAME: "2851 chassis", DESCR: "2851 chassis"
PID: CISCO2851 , VID: V03 , SN
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1 , VID: V01 , SN:
NAME: "2nd generation two port EM voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation two port EM voice interface daughtercard"
PID: VIC2-2E/M , VID: V01 , SN:
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO= , VID: V , SN:
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN:
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
Router#show run
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
card type t1 0 0
logging buffered 3000000
no aaa new-model
clock timezone CDT -6
clock summer-time CDT recurring
network-clock-participate wic 0
network-clock-select 1 T1 0/0/0
ip cef
no ip domain lookup
login on-failure log
isdn switch-type primary-ni
voice-card 0
dspfarm
voice class codec 100
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice class h323 1
h225 timeout tcp establish 2
application
global
service alternate default
controller T1 0/0/0
framing esf
linecode b8zs
pri-group timeslots 1-24 service mgcp
ip tcp synwait-time 5
ip ssh version 2
class-map match-any Data
match access-group name DataTraffic
class-map match-any Voice
match access-group name VoiceTraffic
policy-map qos
class Voice
priority percent 70
class Data
bandwidth percent 5
class class-default
fair-queue
interface Loopback1
ip address x.x.x.x
interface Tunnel1
no ip address
interface GigabitEthernet0/0
ip address x.x.x.x
duplex full
speed 100
service-policy output qos
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
ip route 0.0.0.0 0.0.0.0 x.x.x.x
no ip http server
no ip http secure-server
ip access-list extended DataTraffic
permit ip any any dscp af31
permit ip any any precedence flash
permit tcp any eq 1720 any
permit tcp any any eq 1720
permit tcp any any eq 2428
permit udp any any eq 2427
permit tcp any any range 2000 2002
permit tcp any any range 8001 8002
ip access-list extended voiceTraffic
permit ip any any dscp ef
permit ip any any precedence critical
permit udp any any range 16384 37276
control-plane
voice-port 0/0/0:23
voice-port 0/1/0
auto-cut-through
type 5
signal immediate
voice-port 0/1/1
auto-cut-through
type 5
signal immediate
voice-port 0/2/0
voice-port 0/2/1
timing hookflash-out 500
voice-port 0/2/2
voice-port 0/2/3
ccm-manager fallback-mgcp
ccm-manager redundant-host (publisher)
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server (publisher)
ccm-manager config
mgcp
mgcp call-agent (see footnote*) 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface GigabitEthernet0/0
mgcp bind media source-interface GigabitEthernet0/0
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm (subscriber) identifier 2
sccp ccm (publisher) identifier 1
sccp
dspfarm profile 1 transcode
associate application SCCP
shutdown
dial-peer voice 1000 pots
destination-pattern 9T
direct-inward-dial
port 0/0/0:23
dial-peer voice 999033 pots
service mgcpapp
port 0/2/1
dial-peer voice 999034 pots
service mgcpapp
port 0/2/2
dial-peer voice 999035 pots
service mgcpapp
port 0/2/3
dial-peer voice 1001 pots
destination-pattern 6058
port 0/1/0
dial-peer voice 2000 voip
destination-pattern (fax number)
voice-class codec 100
voice-class h323 1
session target ipv4:(IP address of Publisher)
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 2001 voip
voice-class h323 1
no vad
dial-peer voice 2002 voip
voice-class h323 1
no vad
dial-peer voice 2003 voip
voice-class h323 1
no vad
dial-peer voice 2004 voip
voice-class h323 1
no vad
dial-peer voice 2005 voip
voice-class h323 1
no vad
dial-peer voice 2006 voip
voice-class h323 1
no vad
dial-peer voice 2007 voip
voice-class h323 1
no vad
dial-peer voice 2008 voip
voice-class h323 1
no vad
dial-peer voice 1002 pots
destination-pattern 5
port 0/2/0
dial-peer voice 303030 voip
incoming called-number .
codec g711ulaw
call-manager-fallback
secondary-dialtone 9
max-conferences 4 gain -6
transfer-system full-consult
ip source-address (IP address of GigabitEthernet0/0) port 2000
max-ephones 30
max-dn 60
voicemail (external number)
multicast moh (Class D IP address) port 16384 route (IP address of GigabitEthernet0/0) (IP Address of Loopback 1)
*footnote: This was pointing to an IP I can't find anywhere. I'm thinking this used to be a secondary sub that was removed, I doubt this would cause poor audio though.
12-17-2015 04:05 PM
Are you experiencing poor audio quality within site, from one site to another or from PSTN? Also, just to be sure that you are using all your DSP resources appropriately, I would add following command to voice-card 0 and voice-port
voice-card 0
dspfarm
dsp services dspfarm
voice-port 0/0/0:23
bearer-cap 3100hz
01-26-2016 04:07 PM
I would advise you to run a wireshark, while you use Jabber and set up a test call. Then verify if your RTP is indeed marked as ef. Alternately use SPAN in combination with wireshark and run a test call between deskphones and establish if the phones are indeed using ef.
Let us know how you go.
also, is it intentional to allocate 70% of your bandwidth to voice and video?
