07-30-2019 09:45 AM - edited 07-30-2019 10:05 AM
I'm working on an 11.7 setup that has a main incoming number (POTS) that should ring on all phones. This was initially deployed w/ 10 SCCP phones that all work fine (connection plar to a DN then have that DN appear on all phones as one of the buttons). Recently added a SIP device that needs to be able to answer the same line. I created a DN for it, but from testing it either rings 1 or the other (either the new SIP device or the group of 10 SCCP phones). What would be the best approach to make this work? I was thinking of possibly a hunt-group w/ a the SIP extension and a different common DN for the other phones to share.
i found this https://community.cisco.com/t5/ip-telephony-and-phones/share-dn-between-3rd-party-sip-and-sccp-cme/td-p/1422484 but wasn't sure if there was another way.
Solved! Go to Solution.
08-05-2019 01:10 PM
Please check this post. As per this post, the issue is resolved by configuring same DN tag on Voice register dn <tag> & ephone-dn <tag>.
08-05-2019 01:10 PM
08-06-2019 06:44 AM
Thanks for the link. Good to know going forward. I ended up using a hunt group and having the 2 extensions listed there in parallel but if i run into any issues with that I'll give this a try.
