01-29-2022 10:29 PM - edited 01-29-2022 10:30 PM
I have Cisco CME (C2801) version (12.4(15)T9)
Does this CME and its software support the IP Phone 8841?
and if it doesn't, can it be supported by updating the IOS version of the CME?
01-29-2022 10:44 PM
88xx is supported on cme 12. + But I don’t remember if it supports on come cme 11.
with older version there was a workaround to register the unsupported phone model using voice register pool-type.
10-29-2023 01:51 AM
how can register the unsupported phone model using voice register pool-type ?!
10-29-2023 10:27 PM
Upgrading your IOS will upgrade the CME versions and that will be one option to make the phones supported.
You must use pool-type if the CME versions doesn't support the phone type.
