CME 7.1, 7970 IP Phone looks for ringlist.xml.sgn
SebastianV
Greetings!
I have a 7970 registered to CME 7.1 on a 2801 router running C2801-IPVOICEK9-M, Version 12.4(24)T8.
I created a RingList.xml file with a special ringtone, both the .raw and RingList.xml files are served via TFTP. My other phone (a 7971) is downloading and playing the ringtone just fine.
However, the 7970 is looking for a signed version of the file:
Sep 27 20:03:38.294: TFTP: Looking for ringlist.xml.sgn
Is there a way to have the phone NOT look for a signed version of the RingList.xml?
I don't seem to have the possibility to sign the file from within the telephony service config.
Any pointers appreciated.
R0g22
Delete CTL/ITL files from the phone.
R0g22
Thanks for your fast reply Nipun, it worked like a charm!
