Hi All, i just installed a 8831 phone in CME 10.5 the phone is working fine , but i found that the phone time display on 8831 is incorrect (other mode is ok). and one know what happened? thanks Simon
We have CME 11.7 with SIP Phones 7811, 7821, 8831, 8845, 8851 and all of the phones have the correct time apart of the 8831. 8831 phone has the Firmware 10-3-1SR3-5 which is the latest. Does anyone know how can I fix this? Thank you.
Hi All I would like to know, How does 8800 KEM 2 column number goes? Is it like first pict or 2nd pict? i do not have the phone next to me, otherwise i would be able to config and check. thanks and regards Pragash
We need to configure Jabber for windows only chating ( IM and P) . We do not have licence. Can u please share the steps for jabber without licence for chating only. 1 is it possible to configure jabber for IMP (chating only)- without licence. 2...
Is it possible to run CUE in a KVM without upgrading the flash? Do 3rd party msata drives work? Is there an alternative to msata and nim based ssds for storage?
Hello, I have urgent problem Users with 78xx IP phones have calls dropped & registration failure and phones re registered again And shows on the screen (REG send failure :REGISTER) This happens randomly all the day for 3 or 4 users I upgraded the fi...
Does the Jabber app on iPhone only support integration with the Apple Calendar? We use Google G-Suite for email and calendaring and some users don't sync their G-Suite calendar with the Apple Calendar app and instead use the Google Calendar app. From...
Hi,I am able to login to the assistant console.But the call control status stay down.Is there any configuration which I have miss out.Thanks
Hi,I have an E1 controller that is down indicating a rx AIS....As shown belowE1 0/0/0 is down. Applique type is Channelized E1 - balanced Receiver is getting AIS. alarm-trigger is not set Version info Firmware: 20070320, FPGA: 20, spm_count = 0 ...
I cannot delete a phone in CUCM.I get the message: "Error occurred. One or more record did not get deleted. This CTI Route Point is being used in the Self Provisioing Configuration hence cannot be deleted. "It is CUCM version: 11.5.1.12900-21There a...
Hi, we're planning to upgrade our UCM 11.0.1 to last 11.5.x. With actual version we've also some 7940 and 60 that works properly (actual firmware was 8.1.sr2). We know that UCM version 11.5 remove compatibility with some phone models, but not to 79...
Hi, We are deploying some new 7821s in our environment and we noticed that the new ones don't show a missed call count. Example: when someone calls me and I don't reply, i usually get a missed call icon and between parantheses how many missed calls...
We recently installed Cisco Attendant Console Server version 12 on a Windows Server 2016 virtual machine. While the software all works correctly, the web interface is gruelingly slow. Logging in is slow, accessing menu's is slow, pretty much everyt...
Hi guys, i have a issue on cisco ip phone 6901,when I call short numbers, the connection is done but nothing is heard in the loudspeaker. when I call national numbers everything is ok. We use CUCMA 8.5.1.17900-11 thx
We have implemented 2921 as CUBE, and integrated with Panasonic PBX. Below is our call flow topology. CUCM--- vpn ---(H323)---CUBE-(FXS)---(TC-106)---(FXO)-Panasonic PBX When the call from CM to Panasonic PBX, the call ringing FXO port and picked up...
Subject | Author | Posted |
01-16-2025 02:00 AM | ||
01-08-2025 01:34 AM | ||
01-05-2025 12:44 AM | ||
01-03-2025 09:47 AM | ||
12-30-2024 03:11 PM |
User | Count |
3 | |
3 | |
2 | |
1 | |
1 |
