09-14-2012 11:44 AM - edited 03-16-2019 01:13 PM
hello. I am trying to get an IP phone registering with CME, but it doesnt seem to work. here is what i got:
System image file is "flash:c2800nm-advipservicesk9-mz.151-3.T.bin"
VOIP1#sh telephony-service
CONFIG (Version=8.5)
Version 8.5
VOIP1#sh telephony-service tftp-bindings
tftp-server system:/its/united_states/7960-tones.xml alias United_States/7960-tones.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7960-font.xml
tftp-server system:/its/united_states/7960-font.xml alias English_United_States/7920-font.xml
tftp-server system:/its/united_states/7960-dictionary.xml alias English_United_States/7960-dictionary.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7960-kate.xml
tftp-server system:/its/united_states/7960-kate.xml alias English_United_States/7920-kate.xml
tftp-server system:/its/united_states/SCCP-dictionary.xml alias English_United_States/SCCP-dictionary.xml
tftp-server system:/its/vrf1/XMLDefault7940.cnf.xml alias SEP001E7A263123.cnf.xml
tftp-server system:/its/vrf1/XMLDefault7910.cnf.xml alias SEP0004C1879F50.cnf.xml
tftp-server system:/its/SEPDEFAULT.cnf alias SEPDefault.cnf
tftp-server system:/its/vrf1/XMLDefault.cnf.xml alias XMLDefault.cnf.xml
tftp-server system:/its/vrf1/ATADefault.cnf.xml alias ATADefault.cnf.xml
phone firmware: cmterm-7940-7960-sccp.8-1-2.zip (P00308010200)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme85spc.htm.html
The phone itself doesnt show errors under the status, it just keeps looping between the "configuring ip" and "opening 172.16.1.1" mesages.
I upgraded the phone's firmware to match the requirements of CME8.5. Before the upgrade I got an application loader error or something similar.
Router's configuration is as follows:
VOIP1#sh run
Building configuration...
Current configuration : 2193 bytes
! Last configuration change at 16:35:01 UTC Fri Sep 14 2012
! NVRAM config last updated at 13:17:54 UTC Fri Sep 14 2012
version 15.1
hostname VOIP1
boot-start-marker
boot-end-marker
enable secret 5 $1$xkRi$DOfdEzKCHWqk2wb6KTUUf/
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 172.16.1.1
ip dhcp excluded-address 172.16.1.254
ip dhcp pool VOIPPOOL
network 172.16.1.0 255.255.255.0
default-router 172.16.1.1
dns-server 172.16.1.1
option 150 ip 172.16.1.1
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FHK1427F3EA
license accept end user agreement
redundancy
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.172
encapsulation dot1Q 172
ip address 172.16.1.1 255.255.255.0
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
logging esm config
control-plane
mgcp profile default
telephony-service
max-ephones 5
max-dn 5
ip source-address 172.16.1.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Sep 14 2012 16:33:20
ephone-dn 1
number 1111
name VOIP1_1
ephone-dn 2
number 1112
name VOIP_2
ephone 1
device-security-mode none
mac-address 001E.7A26.3123
type 7940
button 1:1
ephone 2
mac-address 0004.C187.9F50
type 7910
button 1:2
line con 0
logging synchronous
line aux 0
line vty 0 4
password cisco
login
transport input all
scheduler allocate 20000 1000
end
And the debugging of the router's tftp events loops between the following:
Sep 14 16:37:30.623: TFTP: Looking for CTLSEP001E7A263123.tlv
Sep 14 16:37:30.691: TFTP: Looking for SEP001E7A263123.cnf.xml
Sep 14 16:37:30.691: TFTP: Opened system:/its/vrf1/XMLDefault7940.cnf.xml, fd 10, size 1059 for process 377
Sep 14 16:37:30.703: TFTP: Finished system:/its/vrf1/XMLDefault7940.cnf.xml, time 00:00:00 for process 377
VOIP1#
Sep 14 16:38:02.583: TFTP: Looking for CTLSEP001E7A263123.tlv
Sep 14 16:38:02.647: TFTP: Looking for SEP001E7A263123.cnf.xml
Sep 14 16:38:02.647: TFTP: Opened system:/its/vrf1/XMLDefault7940.cnf.xml, fd 10, size 1059 for process 377
Sep 14 16:38:02.659: TFTP: Finished system:/its/vrf1/XMLDefault7940.cnf.xml, time 00:00:00 for process 377
Any ideas? thanks!
09-14-2012 11:52 AM
Hello Heiki,
Check this links:
https://supportforums.cisco.com/docs/DOC-21494
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_phreg.html
Other thing can you ping the IP Phones from CME? The IP Phone configured at the correct VLAN?
Put the command load for the firmware load file.
telephony-service
Load 7960-7940 P00308010200 !---<==== configuration for load command
Leonardo Santana
Rate this if helps
09-14-2012 12:12 PM
yes, the phones acquire ip fine and they are assigned to the voice vlan.
i also got to the point where i compared the configs and saw i was missing the load command.
however i know for sure that on another router with the same model phones i had everything working without the load command. however it could be that on the other setup i had different IOS and phone firmware.
anyway i will give it a try and let you know how it works out. first thing on monday.
thanks for your help!
09-17-2012 08:55 AM
I know this is crazy, but today the original configuration works like a charm. All the equipment is the same, the configuration is the same, all the firmwares are the same. I have no idea why it is working now and didnt work last week. I guess I could call the problem solved.
09-13-2014 06:13 AM
I was having the exact same problem with CME 8.5 and a 7940. Simply rebooting the router fixed the issue. I had not reloaded the router in a very long time and had tried many different configurations on it because it is my lab router. When we make a lot of changes sometimes it is good to reload the system. Thanks for the help everyone.
