CME 8.5 Hunt Group to VM
angel-moon
Level 3
Level 3
All,
running CME 8.5 and I have a hunt group configured with 2 numbers.  If I want unanswered calls to end up in the VM of one of those numbers what should the Final number be? I have put the DN of the  that I want it to go but it just rings forever.
Thanks in advance!  All replies rated.
Ayodeji Okanlawon
One way I thin you can do this is this..
final number has to be voicemail number for cue..
Then you create a mail box with the pilot number as the user, you then add the numbers in the hunt group as e-164 numbers.
So when hunt group forwards to voicemail, VM will be left for the group. Then any of the hunt group members can pick up the message
But Note you wont be able to have a mailbox for the hunt group numbers..
I think another way is to use group voicemail box.....Cant remeber off the top of my head how to do this now..
Please rate all useful posts
