CME 8.6, 2 SIP Phones need to be configured as one Ext.
raid.sameea
Hello Guys
I have CME 8.6 Up and Running...
The manager has 9951 IP Phone (Ext. no 1000) , and he needs another SIP phone with wireless handset. I got Yealink phone with base-station W60B (Ext. no 2000).
The two phones working fine but on different Ext. no 1000 and 2000.
The manager want the following:
1- The two phones to have same Ext. and to be ringing simultaneously when any caller dial 1000.
2- When the manger call any ext. from any phone (9951 or yealink) he want to use Ext. 1000 also.
How I can achieve that by using two SIP phones inside CME 8.6.
Thank you in advance for your help
Best Regards
2 Accepted Solutions
You can using share-dn command under voice register dn . Keep both voice
register dn numbers as 1000
The only thing that I can't remember is the version support for this
command. I recall that it started with 9.x but cross check it.
**** please remember to rate useful posts
I just looked it up and the syntax of the command
*shared-line max-calls *
Its in 9.1. I think you plan for upgrade if need.
Dear Mohamed
Thank you for your kinf reply.
I have searched for this command and unfortunately it looks like not available at CME 8.6, here bellow the output of the command:
voice register dn configuration commands:
after-hour After-hours call blocking
allow allow watcher
auto-answer Define auto-answer for extension
call-forward Define E.164 telephone number for call forward
default Set a command to its defaults
exit Exit from voice register dn configuration mode
huntstop config huntstop for extension
label Define label for SIP phone
mwi Register dn for sip mwi service
name Define caller id name string
no Negate a command or set its defaults
no-reg not register number
number Define E.164 telephone number
pickup-call set the DN to allow call pickup
pickup-group set the call pickup group number for the DN
preference Preference for the attached dial-peer for the dn number
refer handle sip REFER message received from this dn
session-server Define session server tag
shared-line enable shared-line for extension
translation-profile Translation profile
Best Regards
You have this in your output.
shared-line, enable shared-line for extension
This enables shared line in CME.
Response Signature
