CME 8.6, 9951 Phone, External Video/Picture
reindl_mc
Hi all
Is someone aware of bringing a picture from an external source (Sony CH160) to the display of a Cisco 9951/9971 phone which is registered with CME 8.6
I have already tried with different resolutions 320x240 / 640x480 but I always get a http error message, when I point from the phone over URL Button to the weblink.
When I select the link with IE from a pc, then I can see a “oneshotimage”.
Also the camera would be ready for H264, as I know the phone too. Is it possible to establish a H264 connection without initiating a call from the phone.
I have a document from Sony which refers to following syntax:
2.1 Acquiring MPEG-4 or H.264 bit stream
In terms of MPEG-4 or H.264 bit stream, the camera can send them in the form of "HTTP bit stream",
"RTP (UDP) bit stream (unicast)" or "RTP (UDP) bit stream (multicast)". The following are some
explanation how the acquiring sequence will be.
<Method>
GET
<Syntax>
http://ip_adr/image
http://ip_adr/mpeg4
http://ip_adr/h264
http://ip_adr/image[?UdpMode=unicast&UdpPort=<UDP port number>]
http://ip_adr/mpeg4[?UdpMode=unicast&UdpPort=<UDP port number>]
http://ip_adr/h264[?UdpMode=unicast&UdpPort=<UDP port number>]
http://ip_adr/image[?UdpMode=multicast]
http://ip_adr/mpeg4 [?UdpMode=multicast]
http://ip_adr/h264[?UdpMode=multicast]
br
paolo bevilacqua
Cisco phones, including ones with video, do not support web video streams.
