01-28-2013 03:45 AM - edited 03-16-2019 03:23 PM
Do you know if it is possible the Caller who rings to a dual-line DN with an active call on it, to hear a different signal (instead of normal ringing signal)?
Or if it's not, do you know some other way to understand that he/she is in a queue?
The platform is Cisco CallManager Express 8.6.
Thank you very much in advance.
01-28-2013 04:12 AM
Use Huntstop channel command under ephone-dn and this will let calling person know that phone is busy.
Ephone-dn 1 dual-line
Number 1001
Huntstop channel
Ronak Patel
Rate helpful posts.
01-28-2013 04:17 AM
I know this function, but if I use it the call cannot be answered, right? This is not the required scenario.
Thanks anyway!
01-28-2013 04:20 AM
Yes you are ture. I dont think we have any other option natively available in CME.
Ronak patel
01-28-2013 04:30 AM
you can play around with a TCL script but it might be painful to program it, or, give a try to BACD.
Or, if you have a Cisco Unity Express (CUE) module, it would give you even better options.
G.
01-28-2013 09:07 AM
You can use my script "selective ringback tone" for that. It can be acquired on the website mentioned in my profile.
