08-22-2014 09:34 AM - edited 03-16-2019 11:51 PM
Good day experts,
I am not an expert and would like to get help with my objectives.
What I have is IP phone and Analog phone connected to 3825 (CME 8.6) and connected to SIP ITSP.
What I want to do is for IP phone and Analog phone to ring at the same time and who ever answer first gets the call. The rests will stop ringing.
I have heard this is called Parallel Hunt in CME 8.6 but I would like verification for this.
I successfully setup to only redirect incoming call to FXs port but not to IP phone at the same time by using dialpeer. I hope this is possible since I have already invested to the router, fxs card and dsp card. I have a feeling that the easiest setup would be to get ATA box for analog phones.
Also can some one please send me a copy of your's config file for CME 8.6 that successfully configured that is similar to my objective? Like Dial peers, 911, and other stuff specifically for Toronto area if possible? I really appreciate if somebody can help me cause i have been pulling my hair lately. Thanks.
08-23-2014 06:16 AM
Yes, you can configure a blast/parallel hunt group. This is what the configuration would look like for a hunt group -
n the following parallel hunt group example, when callers dial extension 1000, extension 1001, 1002, and so on ring
simultaneously. The first extension to answer is connected. If none of the extensions answers, the call is forwarded to
extension 2000, which is the number for the voice-mail service.
voice hunt-group 4 parallel
pilot 1000
list 1001, 1002, 1003, 1004
final 2000
timeout 20
You can tweak the above sample as per your requirements. Let me know if you got any questions related to this.
HTH,
Nipun
08-23-2014 07:02 AM
08-23-2014 08:11 AM
08-23-2014 05:06 PM
08-27-2014 05:27 AM
You are spot one.
You will need to create translation rule and profile.
Since you are trying to translate your 3 digit extensions to the 10 digit DID number, we can create a generic rule.
voice translation-rule 1
rule 1 /^...$/ /<the number that you need to translate to>/ (the forward slash is necessary)
voice translation-profile OUTBOUND_CALLER_ID
translate calling 1
Just apply the translation profile on an outbound dial-peer in the outgoing direction so that it translates your 3 digit extensions to full 10 digit DID numbers.
dial-peer voice x pots/voip
translation-profile outgoing OUTBOUND_CALLER_ID
You should be good at his point. Let me know if you need any clarifications.
HTH,
Nipun
