CME-8.8 -Hardware Conference not Working
adeep.paul
                   Hello all,
when i am trying to create a second conference session , " Unable to create conference " ===>. (telephony, conference hardware )
When i am using the software conference , i am able to create multiple conference .
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.5.1, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 3
Reported Max Streams: 40, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
Supported Codec: rfc2833 pass-thru, Maximum Packetization Period: 30
Supported Codec: inband-dtmf to rfc2833 conversion, Maximum Packetization Period: 30
TLS : ENABLED
Transcoding Oper State: ACTIVE - Cause Code: NONE
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 12, Reported Max OOS Streams: 0
ephone-dn  18  octo-line
number A001
conference ad-hoc
preference 1
no huntstop
ephone-dn  19  octo-line
number A001
conference ad-hoc
no huntstop
ephone-dn  20  octo-line
number A001
conference ad-hoc
preference 2
ephone-dn  21  octo-line
number 500
conference meetme unlocked
no huntstop
dspfarm profile 1 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 6
associate application SCCP
dspfarm profile 3 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 5
7 Replies 7
Ayodeji Okanlawon
Adeep,
Post your full config. Can you also explain better...What do you mean a second conference session? Do you mean you already have a conference ongoing? How many people were on that conference? Or do you mean you cant add another person to the conference
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
I am trying to create a second conference...but am getting the " Unable to create conference " error message in  the phone.. the conference which i created have three members ...
Can you post a full config or atleat the telephony-service portion.
Yosh
HTH Regards, Yosh
telephony-service
sdspfarm units 10
sdspfarm transcode sessions 25
sdspfarm tag 1 confprof1
sdspfarm tag 2 Transcoder
sdspfarm tag 3 CSE_CONF
no auto-reg-ephone
fxo hook-flash
max-ephones 50
max-dn 300
ip source-address 192.168.5.1 port 2000
service phone webAccess 0
service phone ehookEnable 1
timeouts interdigit 4
system message Computer Solutions East, Inc.
url services
http://192.168.15.2/voiceview/common/login.do
url authentication
http://192.168.15.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
load 7942 SCCP42.9-1-1SR1S.loads
load 7962 SCCP42.9-1-1SR1S.loads
load 7970 SCCP70.9-2-1S.loads
load 7975 SCCP75.9-3-1-1S.loads
load 6941 SCCP69xx.9-2-2-6.loads
time-zone 12
date-format dd-mm-yy
live-record 400
voicemail 399
max-conferences 8 gain -6
hunt-group logout HLog
moh "flash:/MusicOnWaiting.wav"
multicast moh 239.1.1.1 port 16384
web admin system name cseadmin secret 5 $1$yPsl$IOp4k9/Gy/U5v72LVjrmy.
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
Adeep,
Is this a meetme or ad-hoc conference?
Meetme ..But i cant add the command hardware conference ...when i add the hardware conference , only one conferece is allowed in the entire system , te second conferece session will give the error "Unable to create conference"...
This looks like you do not have enough dsp to configure more than one hardware conference session.
You may need to add more dsp to your router. If you send a show diag and a sh run of your gateway, we can tell how many dsp you have and advise further. Hardware conferencing supports a mix of G729 and G711 codec hence requires more DSP
