IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5561 Views
  • 14 replies
Hi,I am using uccx 8.5 with CUCM 8.6.2. I want to know whether the CTI route point can choose the CTI port for calling specifically. In over scenario the CTI route point forward the call to any of the CTI port which are in different device pool. Can ...
Hola quisiera saber si esta vulnerabilidad Ejecución de código arbitrario en la familia de teléfonos Cisco Unified IP 7900esta reconocida oficialmente por Cisco y si en realidad afecta a toda la serie 7900, de la cual se habla en el siguiente enlance...
Hi there,I'm not getting my BR1 gateway registered in cucm.In my br1 gateway if i troubleshoot layer by layer i did the followingsh isdn status=> multiple frame establishedsh ccm-manager=> callmager registered with 10.10.210.10i removed mgcp bind con...
monasir by Level 1
  • 1454 Views
  • 7 replies
Resolved! uc520 isdn trouble
Hi everyone..Im having trouble with calls on a uc520.Then for example i make an incomming call from the outside to a number the phone rings but ether disconnects when pickup or after a certain time.Can anyone give me a hint what could be wrong ?Regar...
