02-05-2007 02:30 PM - edited 03-14-2019 07:52 PM
I am trying to use the default script. However, I have only one queue. I just need B-ACD to run the welcome greeting and then ask the user to dial the extension. I don't want the B-ACD to pass the user to different queues.
Do I have to modify the TCL script or there is a way?
Thanks in advanced
02-05-2007 02:45 PM
The problem is that even with one option only, the script will need one digit as selection before collecting the extension. So unless you are happy with something like "Press 1 followed by the extension desired", you will need a modified script.
02-05-2007 02:46 PM
Is there is an easy way to modify the script. Because I opened the script using a text editor and it is pretty hard to modify!
02-05-2007 03:01 PM
Indeed hacking IVR TCL may be not be hard, but not even a trivial task. I plan to do a little bit of work on that later on, and will come back to this thread when I have news.
02-08-2007 04:41 AM
I hadn't the time to try this yet, but have you tried drop-through mode to the menu entry for dial by extension ?
