CME behavior with call blocking using COR and after hours
jmcornilla
I have a CME 8.X setup.  Call blocking is done by using both CORlists and after-hours blocking.  I assign a phone's calling privilege (can call internal, local, NDD, IDD)by assigning CORlists, but I try to control long distance calling (NDD and IDD) via PIN codes by using after-hours blocking.  Basically, phones that can call long distance should be able to do so only by using PIN codes.
I have configured some phones to be unable to call long distance, but when I login with the PIN, this phone can call any numbers blocked by the after-hours blocking.  Is this the expected behavior when using COR with after-hours blocking?
Actually even 9T conflitcs with 9... as well with anything that begins with 9 and is ended by timeout.
So, do not use dots as long as possible. Use digits matching, for example 9[2-9]....T for numbers that begin with possible digits from 2 to 9, are of variable lenght with a minimum of five digts.
Also, with COR you must use "huntstop" for all DPs that can be matched by any dialed string.
10 Replies 10
paolo bevilacqua
Yes. In fact it's quite possible that you won't need COR in presence of after-hours with PIN override.
The client wanted to handpick phones that will be able to call long distance, then they want employees that own these phones to key in PIN codes before they can call these numbers.  For example, a phone may login and be able to call NDD, but not IDD.  Is there a way to do this or is this a limitation for the CME platform?
Yes, that can be done with COR and/or after-hours PIN override. If it is not working for you then you will have to review the configuration for correctness.
Here are some snippets of the configuration.  Some items have been edited for confidentiality purposes.
dial-peer cor list CALL-LOCAL
member LOCAL
dial-peer cor list CALL-IDD
member IDD
dial-peer cor list USER-LOCAL
member LOCAL
dial-peer cor list USER-LOCAL-GSM-NDD-IDD
member LOCAL
member GSM
member NDD
member IDD
dial-peer voice 123 pots
corlist outgoing CALL-IDD
description *** IDD_CALL ***
translation-profile outgoing PSTN_OUTGOING
destination-pattern 900T
progress_ind setup enable 3
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind disconnect enable 8
port 0/0/0:15
forward-digits all
telephony-service
after-hours block pattern 1 909.........
after-hours block pattern 2 902T
after-hours block pattern 3 903T
after-hours block pattern 4 904T
after-hours block pattern 5 905T
after-hours block pattern 6 906T
after-hours block pattern 7 907T
after-hours block pattern 8 908T
after-hours block pattern 9 900T
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
ephone-dn  11  dual-line
number 1100
corlist incoming USER-LOCAL
ephone  11
mac-address AAAA.AAAA.AAAA
max-calls-per-button 2
type 7942
button  1:11
pin 1234
What I encountered is that although this phone is only configured for local calls via corlist, it can still call IDD after logging in.  Is there anything that I should look into?
You might have other dial-peers allowing the call.
Note to avoid using a translation-profile with variable-lenght numbers use:
destination-pattern 9[0][0][1-9]....T
default forward-digits
Yes, I have a a dial-peer with destination set as 9T with corlist as CALL-LOCAL. I use this as a "catch-all" dial-peer for fastfood and government hotlines that are either 3 or 5-digit numbers only.  However, isn't it that my dial peer with destination 900T will be used because it is the most specific match?
I would also like to add that IDD calls only get permitted after logging in with the PIN code.  Prior to that, the call is blocked for this phone.
I dont think that the fastfood numbers you mentioned can start with 00, so you just should configure destination-pattern accordingly in every dial-peer.
Please remember to rate useful posts clicking on the star below.
Say if I were to configure dial-peers with destinations 9... and 9....., won't these get in conflict with numbers that are longer than those patterns?  Say I dial 9006512345678, won't CME quickly use dial-peer with 9... pattern?
