03-11-2013 01:12 AM - edited 03-16-2019 04:10 PM
I have intalled CCME 8.8, i need to implement call controlling in CME, to get IDD calls phone should request a PIN, for local pstn calls also phone should request a PIN, how can we do this in CME ?
Regds
03-11-2013 01:27 AM
Not possible directly. But you can see if below link can help you
https://supportforums.cisco.com/thread/2144369
Ronak Patel
Rate all helpful post by clicking stars below the answer.
03-11-2013 01:36 AM
you need to implement fac. kindly find the below config
dial-peer cor custom
name fac-int
name user-fac
dial-peer cor list fac-int
member fac-int
dial-peer cor list user-fac
member user-fac
ephone-dn 598 octo-line
number 101 no-reg primary
corlist incoming user-fac
dial-peer voice 100 voip
corlist incoming fac-int
corlist outgoing user-fac
service clid_authen_collect
destination-pattern 900T
session target ipv4:XXX.XXX.XXX.XXX (CME IP address)
incoming called-number 900T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 101 pots
corlist outgoing fac-int
translation-profile outgoing DiscardDigit9
preference 3
port 0/0/0
forward-digits all
no sip-register
Anas
please rate if it is helpful
