CME call Restrictions using PIN
W S H FERNANDO
Level 4
Level 4
I have intalled CCME 8.8, i need to implement call controlling in CME, to get IDD calls phone should request a PIN, for local pstn calls also phone should request a PIN, how can we do this in CME ?
Regds
ronpatel
Level 8
Level 8
Not possible directly. But you can see if below link can help you
https://supportforums.cisco.com/thread/2144369
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
you need to implement fac. kindly find the below config
dial-peer cor custom
name fac-int
name user-fac
dial-peer cor list fac-int
member fac-int
dial-peer cor list user-fac
member user-fac
ephone-dn  598  octo-line
number 101 no-reg primary
corlist incoming user-fac
dial-peer voice 100 voip
corlist incoming fac-int
corlist outgoing user-fac
service clid_authen_collect
destination-pattern 900T
session target ipv4:XXX.XXX.XXX.XXX (CME IP address)
incoming called-number 900T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
dial-peer voice 101 pots
corlist outgoing fac-int
translation-profile outgoing DiscardDigit9
preference 3
port 0/0/0
forward-digits all
no sip-register
Anas
please rate if it is helpful
