02-03-2016 04:13 PM - edited 03-17-2019 05:44 AM
I am learning CME and having trouble modifying the max extensions and max phones in CCP (Telephony Settings). When I click to deliver the modified Telephony Settings, I get the error message:
Configuration failed: Configuring 'tftp-server flash:SCCP69xx.9-0-3-b.loads alias SCCP69xx.9-0-3-b.loads'
Response from device: This alias is already being used. Please use another alias
Since it isn't clear how to change the alias, I tried removing it several times, with "no alias". But when I do the below the alias is still there. Is there an easy workaround for this?
show telephony-service tftp-bindings
02-04-2016 10:25 PM
Hi Mason,
Have you tried doing this with the below:
telephony-service
shut
Try changing the max-ephones and dn after this. If you still get the same error message, try deleting the particular file in flash.
Rajan
02-05-2016 10:34 AM
Thanks for the help. The telephony-service command didn't keep the error message from popping up again. I went and deleted the specified file in flash and went to deliver the changes but then it showed the same error message for a different file. The same process repeated itself for a while, so I've decided to stay clear of CCP and favor the command line instead, at least until an answer is found. Thanks again Rajan.
