IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5922 Views
  • 14 replies
Hi folks,We just bought a brand new 7821 Phone and wanted to test it internally in our labs.We´ve downloaded the COP file mentioned in the Release Notes (cmterm-78xx.10-1-1-9.cop.sgn), restarted TFTP Service, even restarted the Server, but there is s...
fodermat by Cisco Employee
  • 9721 Views
  • 28 replies
Hi, We encountered an issue where in we experienced a busy tone while dialling out. After we traced it, we found that the endpoint in CUCM was registered while the show mgcp endpoints for e1 in voice gateway were down. We have checked also that the ...
Hi Guys, We are encountering now an issue where in we are calling to a toll free number however we are getting a busy tone. After tracing the call, we found out that the we are having a disconnection cause of: (This logs came from the E1 of the VG o...
Hi guys, I would like a recommendation for a call recording server. We actually only need 2 staff to be recorded. Currently we are using a third party call recording server, which cost us USD $8000, this include installation, configuration, maintena...
Xian Li by Level 1
  • 1047 Views
  • 3 replies
Hello.  If I create an ICT between two of our clusters, for fail-over purposes, can phones from one cluster make calls out a PSTN of the other cluster, or is this just for on-net calls between clusters?   Also, we are considering an ICT between a cl...
brown2wab by Level 1
  • 1062 Views
  • 13 replies
Hi community,the last couple days i'm trying hard to get MVA working.I'm familiar with setting it up but the actual system (CUCM 7.1.5.30000-1) reports back an "404 - File not found" error.To be explicit, i used the following URL:http://10.0.0.1:8080...
stschm0012 by Level 1
  • 4137 Views
  • 14 replies
