CME compatibility with phone loads
Tom Ribbens
On http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.htm I seem to be under the impression that CME only supports version 8.4(1) of the 7941 phone loads.  Is that really the case?
I have a CME 7.1 running with "load 7941 SCCP41.8-5-4S" configured. One phone has recently started dropping calls mid-call. Could this be an issue with the version mismatch?
Rob Huffman
Hi Tom,
Specific CME versions are tested with the versions listed on the
"requirements" doc like the one you linked, but are not limited
to those versions. It is often appropriate to upgrade phone firmware levels
on CME and is fully supported
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeinstl.html#wp1003087
I don't think your issue would be related to the relationship
between CME 7.1 and 8-5-4S . I'll have a look for bugs that may be
hitting that version.
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
