CUE 7.4 Licensing Options
Scott Hanson
Level 3
Level 3
Hello everyone,
can someone tell me if mailbox, port and IVR licenses are still obtainable for CUE 7.4 and if so how do I go about ordering?
Thanks.  Replies rated
paolo bevilacqua
Any CUE can be update to a minimum of 8.0.6.
If should look for licenses applicable to that version.
Thanks Paolo,
The Unity Express compatability Matrix seems to indicate that the AIM-CUE module can only up to 7.x
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/compatibility/cuecomp.htm
Is this not the case?  I sure hope I can go to 8.x
You are right. For these, licenses are technically file downloads.
