CME configuration tool
kdonnelly
       I have a customer who wants me to configure a CME as a key system with CUE on an ISM. I remember in the past a CME quick confguration tool that had a wizard setup for PBX or key system. I know that tool is old and doesn't support a 2921 router. Is there a new tool that does the same thing and supports the 2921 router?
Chris Deren
You can use the Cisco Configuration Professional (CCP) which is pretty neat.
HTH,
Chris
Chris Deren
HTH,
Chris
Chris,
I was looking at that. I have an older version that doesn't support 2900 routers. When I go the the Cisco download site all I can find is configuration professional express version 2.7. Which want me lo load it onto the router.. I don't think this is what I'm looking for. Do you know where I can get the correct s/w?
Rob Huffman
Hi there,
Check out the 2.6 version of CCP
http://www.cisco.com/en/US/docs/net_mgmt/cisco_configuration_professional/v2_6/rlsnts/ccp_rel_notes.html#wp45050
Here is the name of the file;
cisco-config-pro-k9-pkg-2_6-en.zip
Configuration Professional Software-2.6
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
