CME - COR List "Internal" not working
rossporubski
Level 4
Level 4
I was asked to add an additional COR to the default. By default everybody in the 20 person facility can dial local and long distance. International is restricted. My predecessor set up a COR to add in International, but never completed the config.
I am trying to setup internal and 911 only. I used this whitepaper [below] to construct my list. It's not working though. I can still dial local and long distance on the lobby phone.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml#maintask1
Here's my config.
dial-peer cor custom
  name internal
dial-peer cor list international
dial-peer cor list Internal
member internal
dial-peer voice 2900 voip
description VoiceMail
destination-pattern 2900
session protocol sipv2
session target ipv4:172.20.50.254
dtmf-relay sip-notify
codec g711ulaw
dial-peer voice 4660 voip
description Auto_Attendant
destination-pattern 4660
codec g711ulaw
no vad
dial-peer voice 8400 voip
translation-profile outgoing PHL
destination-pattern 41....
session target ipv4:172.20.1.10
dial-peer voice 9 pots
description Long-distance
destination-pattern 91[2-9].........
incoming called-number .
direct-inward-dial
port 0/1/0:23
forward-digits 10
prefix 1
dial-peer voice 912 pots
description Local
preference 1
destination-pattern 9[2-9].........
direct-inward-dial
port 0/1/0:23
dial-peer voice 9011 pots
description International
direct-inward-dial
port 0/1/0:23
prefix 011
dial-peer voice 9911 pots
corlist outgoing Internal
description 911
destination-pattern 9911
direct-inward-dial
port 0/1/0:23
forward-digits 3
Thank you for any help
0 Replies 0
