CME/CUE License Information
dvanzee
Level 2
Level 2
Can Someone tell me how to figure out what licensing I have purchase for a CME/CUE from the router itself? Is there a different sections for CME and CUE?
Rob Huffman
Hi Daniel,
For CUE;
CUE> show software licenses
show software
To display characteristics of the installed software, use the show software command in Cisco Unity Express EXEC mode.
show software {directory | download server | licenses | packages | versions}
Syntax Description
directory
Displays the software directory.
download server
Displays the IP address of the FTP server.
licenses
Displays the terms and limits of the purchased license for the system.
packages
Displays the configured Cisco Unity Express application packages.
versions
Displays the current versions of the configured software and applications.
CUE> show voicemail
To display the properties of the voice-mail system, use the show voicemail command in Cisco Unity Express EXEC mode.
show voicemail {detail {mailbox | user} name | limits | mailboxes [idle number-of-days] | usage | users}
Syntax Description
Displays the details for a general delivery mailbox or a subscriber with the name value. For a general delivery mailbox, use the owner's name, not the name of the group.
limits
Displays default values for all mailboxes.
mailboxes
Displays all configured mailboxes and their current storage status.
idle number-of-days
(Optional) Displays all configured mailboxes that have been inactive for at least the specified number of days.
usage
Displays how much of the voice-mail system's capacity has been used or configured.
users
Lists all the local voice-mail subscribers.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel3_1/command/reference/s_cmds.html#wp1024084
For CME;
Usage Guidelines
The max-ephones command limits the number of Cisco IP phones supported on the router. The maximum number you can set is platform- and version-dependent. Use CLI help to determine the maximum number of ephones you can set, as shown in this example:
Router(config-telephony)# max-ephones ?
<1-48> Maximum phones to support
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/command/reference/cme_m1ht.html#wp1041838
Cisco CallManager Express/Cisco Unity Express Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml
Hope this helps!
Rob
Rob Huffman
Hi Daniel,
For CUE;
show software
Syntax Description
directory
download server
licenses
packages
versions
CUE> show voicemail
Syntax Description
limits
mailboxes
idle number-of-days
usage
users
For CME;
Usage Guidelines
Hope this helps!
Rob
Hi Rob - Thank you for quick respone. I was able to figure out my phone capacity. However the commands listed under the Cue section don't appear to be working. If I am running CME and CUE on the same module would it be licensed based on teh max-ephones?
